The engine is alive... #702711
05/19/10 08:19 PM
05/19/10 08:19 PM
Stockholm, Sweden
TomsCharger70 Offline OP
Stockholm, Sweden
Little update
Got the engine running again.. sadly the video quality is not the best, but trust me, the engine does sound really nasty, and nasty in a good way...
http://www.youtube.com/watch?v=D56T9DpPs3A
Someone with a hawkeye might notice the A/F meter numbers, the number are not correct, the A/F gauge is showing erratic numbers, needs a calibration...
The thing thats causing me the most headache at this moment, is that what ever I do, I just cant get the damn shifter cable/trans gear lever adjusted Last time I found the sweet spot right away, but this time
There is also some weird issue going on with the charging system I need to figure out...
The first race for the season is no more than one and a half weeks away, not that confident right now, that Ill be at the starting line..
/Tom
Re: The engine is alive... [Re: TomsCharger70] #702712
05/19/10 10:35 PM
05/19/10 10:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
sweet!
Re: The engine is alive... [Re: Dodgem] #702713
05/20/10 07:14 AM
05/20/10 07:14 AM
tboomer Online work
tboomer  Online Work
Good luck!!
