Little update
Got the engine running again.. sadly the video quality is not the best, but trust me, the engine does sound really nasty, and nasty in a good way...
http://www.youtube.com/watch?v=D56T9DpPs3ASomeone with a hawkeye might notice the A/F meter numbers, the number are not correct, the A/F gauge is showing erratic numbers, needs a calibration...
The thing thats causing me the most headache at this moment, is that what ever I do, I just cant get the damn shifter cable/trans gear lever adjusted
Last time I found the sweet spot right away, but this time
There is also some weird issue going on with the charging system I need to figure out...
The first race for the season is no more than one and a half weeks away, not that confident right now, that Ill be at the starting line..
/Tom
