Electronic Ignition Conversion #702648
05/19/10 06:56 PM
05/19/10 06:56 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Im looking to Wire in a stock electronic Ignition in my 72 Dodge Van.
I have the ECU,Dizzy,and harness.
It is my undertanding that the Black/Yellow wire on the harness goes to the - side of the coil.
Then theres a wire I have to supply that goes from the + side of the coil to the Ballast Resistor.
Then theres one wire that comes from the electronic ignition harness,that goes to the other side of the Ballast Resistor.
The other 2 wires in the Electronic ignition harness are for the Distributor and have a connector on them.
So now that I have the wiring sorted out I need to know what wire goes to what side of the ballast resistor?
My ballast resistor currently has 2 red wires going to one side of it and a 2 wires going to the other side,one is yellow and one is red.
Does the wire I provided to the + side of the coil go to the side where the red and yellow wires are on the ballast,or on the other side where theres 2 red wires going to the ballast resistor?
Re: Electronic Ignition Conversion [Re: SPWC] #702649
05/19/10 07:16 PM
05/19/10 07:16 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
You have to break out a test light or volt meter. Whichever side has 12 volts with the key in the on position is the side you want to tap into.
Re: Electronic Ignition Conversion [Re: GTX MATT] #702650
05/19/10 07:23 PM
05/19/10 07:23 PM
SPWC Offline OP
SPWC  Offline OP
I have turned the key to the "ON" position and Its hot on both sides of the ballast,according to my test light.
Re: Electronic Ignition Conversion [Re: GTX MATT] #702651
05/19/10 07:26 PM
05/19/10 07:26 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
This is some of the stuff I have on the computer
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Electronic Ignition Conversion [Re: HealthServices] #702652
05/19/10 07:31 PM
05/19/10 07:31 PM
So Cal
So Cal
Single ballast
Re: Electronic Ignition Conversion [Re: SPWC] #702653
05/19/10 07:33 PM
05/19/10 07:33 PM
So Cal
So Cal
If you are using a test light unplug and test the wire.
Re: Electronic Ignition Conversion [Re: SPWC] #702654
05/19/10 08:20 PM
05/19/10 08:20 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
It will be hot on both sides, but the voltage will not be the same. A meter will indicate that there is a difference of around 6 volts between the two points. The light should be dimmer on one side than on the other side. Unless you have calibrated eyeballs, the light cannot tell you the voltage.
Craig
Re: Electronic Ignition Conversion [Re: HealthServices] #702655
05/19/10 08:27 PM
05/19/10 08:27 PM
SPWC Offline OP
SPWC  Offline OP
Yea...I just realized my mistake on testing the hot side of the ballast with it plugged in on both sides...DOH!!!
So as I read the diagram for the single ballast I decipher it as the following:
The wire that I supply to go to the + positive side of the coil,gets connected on the side of the ballast that DOESNT read HOT when the ballast is unplugged and the key is in the ON position.
The #1 position in the electrical harness(ECU) goes to the side of the ballast that reads HOT when the ballast is unplugged and the key is in the ON position...
Is this correct,or is my deciphering clear as Mud?
Re: Electronic Ignition Conversion [Re: SPWC] #702656
05/19/10 09:18 PM
05/19/10 09:18 PM
So Cal
So Cal
I would have to say 'mud'
With the single ballast pictured if you disconnect the blue wire with the ignition on there would be no voltage at either end of the ballast. If you put a test light at the blue wire thought (connected or not) it would give you voltage.
But you would put the wire (brown in the picture from the coil) on the opposite end of the resister from where the power wire is.
Re: Electronic Ignition Conversion [Re: HealthServices] #702657
05/19/10 09:19 PM
05/19/10 09:19 PM
So Cal
So Cal
Sorry I'm in class again...
Re: Electronic Ignition Conversion [Re: HealthServices] #702658
05/19/10 09:36 PM
05/19/10 09:36 PM
SPWC Offline OP
SPWC  Offline OP
Im using the "piggyback connectors" as recommended in the Tech Archives when doing this conversion.
I now have everything hooked up(with the exception on the Dizzy,which I havent installed yet).I have disconnected the piggyback connectors from the ballast with the wiring still connected to them.
I turn the key to the "on" position and have power on both sides of the wiring now when I touch the test light to them...Is this how its supposed to be?
Re: Electronic Ignition Conversion [Re: SPWC] #702659
05/19/10 09:42 PM
05/19/10 09:42 PM
So Cal
So Cal
Re: Electronic Ignition Conversion [Re: HealthServices] #702660
05/19/10 09:46 PM
05/19/10 09:46 PM
SPWC Offline OP
SPWC  Offline OP
So just a quick "what if"
What if I was to not ask the question here and install the wires and end up putting them on backwards?
Whats the worst that could happen?
Oh and thanks for walking me through this. Ive done 2 of these before,but its been a little while since,so I just wanted to make sure all was correct.
Re: Electronic Ignition Conversion [Re: SPWC] #702661
05/19/10 09:47 PM
05/19/10 09:47 PM
So Cal
So Cal
Burn up the coil if you run it too long.
Re: Electronic Ignition Conversion [Re: HealthServices] #702662
05/19/10 09:49 PM
05/19/10 09:49 PM
SPWC Offline OP
SPWC  Offline OP
Oh ok...thats not toooo bad.
Vehicle isnt roadworthy yet anyway. Again Thanks a bunch!!
