484 purple cam install 4 advance or straight up #698274
05/15/10 08:54 AM
05/15/10 08:54 AM
st.cloud fl
d-150 Offline OP
Smarter than a 5th grader?
d-150  Offline OP
st.cloud fl
my combo 1977 dodge 2 wheel drive truck. stock 440 smogger 323 gears.would it be better to advance this cam for more low end or straight up.
Re: 484 purple cam install 4 advance or straight up [Re: d-150] #698275
05/15/10 09:14 AM
05/15/10 09:14 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
call m/p, check your cam card. maybe the adv is built in?
Re: 484 purple cam install 4 advance or straight up [Re: d-150] #698276
05/15/10 09:52 AM
05/15/10 09:52 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would install it 5 to 6 advance or 102 or 103 intake lobe centerline.
talking with MP hotline is like talking with a walmart greeter except the walmart greeter likely knows more
Re: 484 purple cam install 4 advance or straight up [Re: d-150] #698277
05/15/10 10:06 AM
05/15/10 10:06 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
my advice would be to NOT use that cam at all. The stock cam will work better w/ your combo. It won't matter how much you advance it.
Coming soon!!!!
Re: 484 purple cam install 4 advance or straight up [Re: d-150] #698278
05/15/10 10:09 AM
05/15/10 10:09 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
A higher stall converter is also required with that cam.
Re: 484 purple cam install 4 advance or straight up [Re: buildanother] #698279
05/15/10 10:20 AM
05/15/10 10:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
and a good intake and headers and at least 3.91's if you have it, sell it and call summit. Their small cam will work good for what you have
Re: 484 purple cam install 4 advance or straight up [Re: d-150] #698280
05/16/10 11:42 AM
05/16/10 11:42 AM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Only your degree wheel will know for sure.
Re: 484 purple cam install 4 advance or straight up [Re: torkrules] #698281
05/16/10 12:07 PM
05/16/10 12:07 PM
Adv it 4 if it's already in and if it is not already in then what Mr Yuck said, get one more suited to your app
