Carb spacer on a prochargerd engine ?
#696881
05/13/10 04:04 AM
05/13/10 04:04 AM
Posts: 91 SWEDEN
Mr500_wedge
SWEDEN
Hi Wondering if a 1" carb spacer does any deferens in performance with a prochargerd engine?. I converted my carbureted engine to prochargerd and left the spacer on, The problem is that the engine won’t fit under the hood with the spacer on. If I lose performance by removing it I rather modify the hood ![](/ubbthreads/images/graemlins/hammer.gif) . Thanks, Toni
Post deleted by Defbob
[Re: Mr500_wedge]
#696886
05/14/10 02:28 AM
05/14/10 02:28 AM
Re: Carb spacer on a prochargerd engine ?
#696887
05/15/10 12:46 AM
05/15/10 12:46 AM
Posts: 91 SWEDEN
Mr500_wedge
SWEDEN
On a boosted app don't think it will make any diff. the spacer helps with the vacume signal for the carb in a NA situation. now you forcing air down the throat of the carb, vacume signal is non exsistant. IMO.
It would be interesting to test it on a Dyno, with and without spacer. My Dyno was with a tight schedule, so no time for testing that .
[Re: go-fish]
#696890
05/18/10 02:06 PM
05/18/10 02:06 PM
Posts: 91 SWEDEN
Mr500_wedge
SWEDEN
This is true. A bigger carb hat is where the power is at. When people are looking for all those little ponies and trying to squeeze everything they have out of their boosted engine they go to a big carb hat and not a big spacer. I asked the Supercharger Store about carb spacers and hats, they told me to forget about the spacer and get an upgraded carb hat from the stock Procharger hat their kits come with. So, your spacer couldn't be helping you that much to make you want to cut up a hood and buy scoops. If you are looking for any power that is there and are resigned to the idea of cutting your hood then ditch the spacer anyway and go with one of these http://www.superiorairflow.com/
Yep I got the big carb hat from Superior airflow . So I wonder is the spacer making any hp, or wit out it I will gain some torque . Anyone try the difference on a dyno?
[Re: Mr500_wedge]
#696891
05/18/10 04:07 PM
05/18/10 04:07 PM
Posts: 693 Coronado, CA
go-fish
Coronado, CA
Hey! I got a PC carb too. They're great. I am so pleased with it (the Supercharger Store sent it with the D1-SC kit) I called them and told them what great product they have.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
[Re: go-fish]
#696892
05/19/10 10:36 AM
05/19/10 10:36 AM
Posts: 91 SWEDEN
Mr500_wedge
SWEDEN
I got my procharger kit (F1 kit) from Supercharger store, very happy with it, PC carburetor, works fine .
