Re: New Slant Six build
[Re: j.mcconnell]
#696646
06/11/10 07:34 AM
06/11/10 07:34 AM
Posts: 365 Motor City
Shaker223
Motor City
is that piece with the BOV's pre-made by someone? why duals? i guess the wastegate is down front somewhere?
Yes, the BOV pice is pre made. Cheap and effective. I used duals because a single could not keep up with the turbo.
The turbo is a Buick style and the wastegate is internal.
[Re: ksj]
#696648
06/23/10 11:54 PM
06/23/10 11:54 PM
Posts: 294 Minnesota
RockChip
Minnesota
That six looks really SWEET !!!!!!! Lookin forward to see what she runs,
[Re: 76dodgeboy]
#696654
06/26/10 01:50 PM
06/26/10 01:50 PM
Posts: 2,260 IL
furious70
IL
I thought us 1st gen (89-93) guys have the H1C mostly. Looks like some of both googling, but I'm not sure of the differences.
5.9L engine with revband to 3000rpm and comfortable up to 25-30psi b4 you push too far out of the sweet spot. It'll work for you if you'll be putting similar air through it (smaller engine, but up to twice the rpms?) and want to push some higher boost through it. Though stock those trucks only ran 10-15psi.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#696656
06/27/10 02:32 AM
06/27/10 02:32 AM
Posts: 350 Grande Prairie, Alberta, Can.
CW25
Missed this earlier but yes you are correct it was the H1C. I think the H1E is larger in all ways but I don't think alot larger. Not exactly sure what they were on... Probably a C series stationary engine? I think it is the same as a HX40.
Back on topic though. What happened to the slant? We need a update.
[Re: Shaker223]
#696661
07/02/10 02:58 PM
07/02/10 02:58 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
BURN DOWN THE SHOP!!!!! OK, maybe we'll let them slide this time since they worked with you. I think you's just skeered to show what your wee little beastie did.
