Page 3 of 5 1 2 3 4 5
Re: New Slant Six build [Re: Shaker223] #696644
06/08/10 12:35 PM
06/08/10 12:35 PM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
Thanks.
Re: New Slant Six build [Re: ksj] #696645
06/10/10 10:23 PM
06/10/10 10:23 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
is that piece with the BOV's pre-made by someone? why duals? i guess the wastegate is down front somewhere?
Re: New Slant Six build [Re: j.mcconnell] #696646
06/11/10 07:34 AM
06/11/10 07:34 AM
Motor City
Shaker223 Offline OP
Motor City
Yes, the BOV pice is pre made. Cheap and effective. I used duals because a single could not keep up with the turbo.
The turbo is a Buick style and the wastegate is internal.
Re: New Slant Six build [Re: Shaker223] #696647
06/23/10 06:39 AM
06/23/10 06:39 AM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
Update.Im seriously thinking of doing something similar.Out of the ordinary and hauls the azz.Kind of like me.
Re: New Slant Six build [Re: ksj] #696648
06/23/10 11:54 PM
06/23/10 11:54 PM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
That six looks really SWEET !!!!!!!
Lookin forward to see what she runs,
Re: New Slant Six build [Re: RockChip] #696649
06/24/10 02:46 AM
06/24/10 02:46 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Would a holset H1E be good for a Stock Slant turbo build? What all would you suggest I would need. I have an Aussie Speed SLANT SIX 4bbl intake aswell. I dont need tons of power. Itll be in an 80 shortbox D100 with an 833od
Re: New Slant Six build [Re: 76dodgeboy] #696650
06/25/10 10:35 AM
06/25/10 10:35 AM
Motor City
Motor City
Actually, I'm not that familure with that turbo. The best thing to do is to find the compressor map and see how it fits. Since the 225 is about the same size as the Buick 231- 3.9L, I followed on their boards to see what was working for them.
Re: New Slant Six build [Re: Shaker223] #696651
06/25/10 12:18 PM
06/25/10 12:18 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I believe its a stock turbo for a 94 Diesel.
Re: New Slant Six build [Re: 76dodgeboy] #696652
06/26/10 12:53 AM
06/26/10 12:53 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
The H1E is off of the 89-93 series cummins. They had no internal wastegate and used a larger exhaust housing than the later HX35. It probably wouldn't spool that well. Not sure what the stock buick 3.8 turbo would probably work alright.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: New Slant Six build [Re: CW25] #696653
06/26/10 01:01 AM
06/26/10 01:01 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Sorry for the hi-jack but would it work better on a 318 than. I thought I read somewhere that it was for a 94. My bad. I dont need a tone of power. It would be more for fuel economy and be driven 50 plus miles a day on the interstate if I can ever find a job again sorry
Any updates on your build?
Re: New Slant Six build [Re: 76dodgeboy] #696654
06/26/10 01:50 PM
06/26/10 01:50 PM
IL
furious70 Offline
furious70  Offline
IL
I thought us 1st gen (89-93) guys have the H1C mostly. Looks like some of both googling, but I'm not sure of the differences.
5.9L engine with revband to 3000rpm and comfortable up to 25-30psi b4 you push too far out of the sweet spot.
It'll work for you if you'll be putting similar air through it (smaller engine, but up to twice the rpms?) and want to push some higher boost through it. Though stock those trucks only ran 10-15psi.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: New Slant Six build [Re: 76dodgeboy] #696655
06/26/10 08:27 PM
06/26/10 08:27 PM
CW25 Offline
CW25  Offline
If you are looking for something very basic it would work on a pretty stock 318.
Re: New Slant Six build [Re: furious70] #696656
06/27/10 02:32 AM
06/27/10 02:32 AM
CW25 Offline
CW25  Offline
Missed this earlier but yes you are correct it was the H1C. I think the H1E is larger in all ways but I don't think alot larger. Not exactly sure what they were on... Probably a C series stationary engine? I think it is the same as a HX40.
Back on topic though. What happened to the slant? We need a update.
Re: New Slant Six build [Re: CW25] #696657
06/27/10 09:22 AM
06/27/10 09:22 AM
Motor City
Motor City
I'm hoping to go to the chassis dyno 7/2/10.
Re: New Slant Six build [Re: Shaker223] #696658
06/27/10 03:23 PM
06/27/10 03:23 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Good luck
Re: New Slant Six build [Re: furious70] #696659
06/30/10 03:24 PM
06/30/10 03:24 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
My 92 CTD pushes 27 psi and redlines at 2400 rpm. I wish it'd turn 3000 but I haven't replaced the factory governor spring.
- Stu Harmon
Re: New Slant Six build [Re: feets] #696660
07/02/10 11:44 AM
07/02/10 11:44 AM
Motor City
Motor City
They could not get the dyno to read data. They messed with it for two hours & no luck. They said they would give me a free dyno session next time for wasting so much of my time (obviously, no charge here either).
Weather was perfect too.
Re: New Slant Six build [Re: Shaker223] #696661
07/02/10 02:58 PM
07/02/10 02:58 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
BURN DOWN THE SHOP!!!!!
OK, maybe we'll let them slide this time since they worked with you.
I think you's just skeered to show what your wee little beastie did.
- Stu Harmon
Re: New Slant Six build [Re: feets] #696662
07/04/10 12:13 AM
07/04/10 12:13 AM
Motor City
Motor City
This is all I got...no numbers and a bunch of aborted pulls.
http://www.youtube.com/watch?v=0oC9BomooF4
Re: New Slant Six build [Re: Shaker223] #696663
07/04/10 10:55 AM
07/04/10 10:55 AM
IN
ahy Offline
ahy  Offline
IN
It sounds great. Hope you try again on the dyno!
