47 desoto hood removal? #695023
05/11/10 02:47 PM
05/11/10 02:47 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i just started disassembly of my 47 desoto, its the first premuscle car era car i`ve worked on. i see 2 bolts that hold the hinge onto the body but its the springs i`m having a problem with, how do i get them off?
Re: 47 desoto hood removal? [Re: 65rbdodge] #695024
05/11/10 03:03 PM
05/11/10 03:03 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Been awhile since I did mine but, I think I just unbolted the hinge from the fender ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 47 desoto hood removal? [Re: bigdad] #695025
05/11/10 03:35 PM
05/11/10 03:35 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
First, this ain't a Dart hood! Strap that thing to some strong supports before even thinking about removing bolts. Better to have a couple strong friends.
Next, try to get a manual or at least some info online. They did things a little different back then.
Here's one source.
http://www.imperialclub.com/Repair/index.htm
Now, soak all bolts with good penetrating oil. 40 year old bolts are easier to remove than 60 year old bolts.
After that, take a good look at how it's mounted and make alignment marks.
Then remove the bolts and remove the hood. To remove the springs from the hinges is a separate ordeal. Be Careful, they are STRONG!
Re: 47 desoto hood removal? [Re: RodStRace] #695026
05/11/10 03:51 PM
05/11/10 03:51 PM
n.e. pa.
n.e. pa.
the spring/hinge look like seperate units. the spring is vertical and goes down inside the fender.
Re: 47 desoto hood removal? [Re: 65rbdodge] #695027
05/11/10 04:35 PM
05/11/10 04:35 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
From the Chrysler website on Yahoo, Post War Heavy Metal (PHWM)
I have a 48 desoto that the previous owner has taken the springs off of
the hood hinges. Does anyone have a trick about how to replace these
springs? I believe I have the correct springs but for the life of me,
I can't install them
Get under the car with the spring in hand. I have done it with a glove on my hand but a tool to hold the loop in the spring will do well. Hook the spring in to the hood where it should go and pull it down and hook it to the place where the other end should go on the body.
I am doing this from memory but look it over and think about it. It will go fine. I do not remember if the hood should be closed or open.
I did something like this and it worked well. I used a rope in a loop, hung the hinges on the top with the loop down to where it is easily reachable, put a bar thru the rope to pull the spring down and hook it.
Does that help?
