How do you remove adhesive from Lexan?? #694540
05/10/10 10:18 PM
05/10/10 10:18 PM
Russiaville, IN
mopar376d Offline OP
Russiaville, IN
Bought a car and removed some numbers and various stickers with a heat gun.
Some of the cheap stcikers left a lot of adhesive.
How do I get this off without scratching and damaging the Lexan windows?
Why does divorce cost so much? Because it is worth it!!!!!
Re: How do you remove adhesive from Lexan?? [Re: mopar376d] #694541
05/10/10 10:37 PM
05/10/10 10:37 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Use WD-40 and a soft rag to clean glue residue. Clean wd-40 with alcohol, then use a plastic polish to clean up lexan. You can buy this at autozone or advance auto parts in the wax/cleaner section.
Brian Dunnigan
Re: How do you remove adhesive from Lexan?? [Re: mopar376d] #694542
05/10/10 10:42 PM
05/10/10 10:42 PM
Painters alcholol(can't remember the proper name, denatured alcholol I think) will remove the adhesives without hurting the lexan according to one of the more popular aircraft lexam window makers I had a airplane that had aircraft paint overspray on the lexan windows from that company and that is what they recommned to remove the over spray followed up with a good brand lexan window cleaner BTW, Pledge furnisher polish works excellent as a lexan window cleaner, many small aicraft owners swear by it rub it on with a clean, soft cotton cloth and rub while it drys, it even hides small scratches while flyiing into the sun in the morning or evening
Re: How do you remove adhesive from Lexan?? [Re: Cab_Burge] #694543
05/11/10 02:03 AM
05/11/10 02:03 AM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
I used both Isopropylalcohol and nail polish remover-acetone free.
The nail remover was better, but left a thin coat of oil, which the Isopropyl. then removed as a last step.
I only use a regular hairdryer, as not to get to much heat on the lexan as a heat gun can make.
I had so many stickers on my rear window, so I eventually broke a nail on one of my thumbs, not funny at all...
Post deleted by Defbob [Re: RT540] #694544
05/11/10 02:30 AM
05/11/10 02:30 AM
Re: How do you remove adhesive from Lexan?? #694545
05/11/10 10:22 PM
05/11/10 10:22 PM
Russiaville, IN
Russiaville, IN
Thank you guys for the replies.
I picked up some of the painters alcohol and have some WD40 at home. Not sure if I have goo bee gone.
I know "goof off" is a very good cleaner but it eats lexan.
