70 Bee Steering Wheel,Replace/Redo???What Would You Do? #694367
05/10/10 06:55 PM
05/10/10 06:55 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
OK Guys what would you do Replace or Redo the steering wheel,it's a 1970 SuperBee survivor car that's in great condition and I don't know which way to go...
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: Hemiruss] #694368
05/10/10 07:15 PM
05/10/10 07:15 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Russ,
I would redo what you have for now while on the look out for a org unrestored wheel that would be right at home on that car.
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: rrunner] #694369
05/10/10 07:25 PM
05/10/10 07:25 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If it's a survivor don't you do nothing?
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: Morty426] #694370
05/10/10 07:31 PM
05/10/10 07:31 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Why? That's not normal wear, looks like something got on the wheel. A redone wheel or a wheel change won't change the survivor status.
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: Morty426] #694371
05/10/10 07:34 PM
05/10/10 07:34 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
That looks like a "smooth" '68 or '69 steering wheel that's been painted green, not the "pebble-grain" '70 version. Which I don't know if anyone could "restore" a pebble-grain wheel. Do you have a b'cast for the car? Maybe it lost a MINT woodgrain wheel somewhere along the way?
BE & A has a reproduction green '70 wheel, an alternative while you look for a MINT original.
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: rrunner] #694372
05/10/10 08:46 PM
05/10/10 08:46 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
It's a Dec,12 1969 built car and it's smooth on the "ring"area and has a"grain" finish on the spokes under the horn ring,does that sound right or is it just worn on the ring???
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: Hemiruss] #694373
05/10/10 08:47 PM
05/10/10 08:47 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
RING
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: Hemiruss] #694374
05/10/10 08:49 PM
05/10/10 08:49 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
Replace it with another one. No harm done.
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: 6bblgt] #694375
05/11/10 10:48 PM
05/11/10 10:48 PM
WOODGRAINWHEELS.COM Indiana
plumbeeper Offline
plumbeeper  Offline
You won't find a correctly restored pebble grain finish and finding a perfect original unworn wheel would be even harder. Buy a new green one from BEA Parts, dull it down slightly with very fine (0000) steel wool so it has just a little worn look, clean up your spoke cover with some Super Clean (purple stuff) and a stiff tooth brush, bolt it on and go...Now you have a survivor looking wheel.
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: plumbeeper] #694376
05/12/10 08:21 AM
05/12/10 08:21 AM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Thanks Dave so I guess you don't do them??
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: Hemiruss] #694377
05/14/10 10:52 PM
05/14/10 10:52 PM
plumbeeper Offline
plumbeeper  Offline
I stay busy enough with the woodgrain style wheels which are what I like doing the best. I would not attempt to do the pebble grain finish if it's already worn off as most of them are besides you can buy them new from BEA Parts cheaper than what you could have any reputable restoration shop restore it.
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: plumbeeper] #694378
05/14/10 10:55 PM
05/14/10 10:55 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Thanks again Dave I'm glad of your honesty.....
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: Hemiruss] #694379
05/17/10 05:45 PM
05/17/10 05:45 PM
O
OLD318 Offline
OLD318  Offline
O
My
This is not what you want to hear but..
Save the horn ring, ditch the wheel.
For the time and effort to try and repair/refinish that one, you could buy
the repro 70 and be done with it.
You can then redye both with vinyl dye from
JustDashes and only experts will know the difference.
If they make a repro 69 wheel,
(regardless of the color) you could get that one.
and then redye with the horn ring.
Other options: (not what you want to hear either)
wrap it leather... and redye the horn ring.
You could use Black or Dark Green...
I know, I know, not an option from the factory
but...You can actually make them look really nice that way... or at least until you find an original...
Best of luck to you...
those steering wheels are frustrating.
Most are truly pieces which did NOT stand the test of time!
Re: 70 Bee Steering Wheel,Replace/Redo???What Would You Do? [Re: OLD318] #694380
05/17/10 08:20 PM
05/17/10 08:20 PM
Ft.Myers,Florida
Hemiruss Offline OP
Hemiruss  Offline OP
Ft.Myers,Florida
Yea it's one of those things which way...Mike has them 4 sale for about $225,it's repo but I thing the best way....I cant remember the guy in Ca.but he's about $800 to redo my orginial 1...so I'm trying to spend my $$$$ where I really need to,like dash switchs,dash repair..(( AGAIN)).and so on....
