My
This is not what you want to hear but..
Save the horn ring, ditch the wheel.
For the time and effort to try and repair/refinish that one, you could buy
the repro 70 and be done with it.
You can then redye both with vinyl dye from
JustDashes and only experts will know the difference.
If they make a repro 69 wheel,
(regardless of the color) you could get that one.
and then redye with the horn ring.
Other options: (not what you want to hear either)
wrap it leather... and redye the horn ring.
You could use Black or Dark Green...
I know, I know, not an option from the factory
but...You can actually make them look really nice that way... or at least until you find an original...
Best of luck to you...
those steering wheels are frustrating.
Most are truly pieces which did NOT stand the test of time!
