Well I was able to get the trans put back in yesterday,had a few problems,first was that I made a bracket to hold the kickdown lever all the way back,when I shifted from 1st to 2nd it would hit 2nd and lock up on the jackstands but if you shifted to 3rd it was fine.I un hooked my bracket and let the lever go forward and it worked fine.
I still have not been able to take it for a drive because of this rain.
This is the pos tf-3 kit in the trans.I also got the new Prosystems carb bolted on and this thing sounds so crisp now.I just wanted to give you all a update on my tranny woes.
