727 question #693409
05/09/10 08:29 PM
05/09/10 08:29 PM
hartsburg mo
biggerredz71 Offline OP
hartsburg mo
I was just wondering if there is any benefits to running a kick down cable when running a manual valve body?I just got the tranny back from my trans guy and it has a kick down cable installed on it and I didnt have one before.I havent talked to my builder about this yet and was wondering what you all's opinions are.Thanks
Re: 727 question [Re: biggerredz71] #693410
05/09/10 09:06 PM
05/09/10 09:06 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
Maybe so it shifts softer at low speed?
I wouldn't want it.
Re: 727 question [Re: DodgeCharger] #693411
05/09/10 09:11 PM
05/09/10 09:11 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Most if not all aftermarket manual VB's eliminate the kick down.
Yes, you could put the lever and linkage on but it wont do anything.
Re: 727 question [Re: DodgeCharger] #693412
05/09/10 09:12 PM
05/09/10 09:12 PM
hartsburg mo
hartsburg mo
I really dont want to have to mess with it if i dont need to.I will call my builder in the am and see whats up.
Re: 727 question [Re: biggerredz71] #693413
05/09/10 09:15 PM
05/09/10 09:15 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
What kind of VB is it?
Brand, part #
Re: 727 question [Re: WILD BILL] #693414
05/09/10 09:23 PM
05/09/10 09:23 PM
hartsburg mo
hartsburg mo
Bill I think the put a kit in the valve body to make it a manual vb,does this sound right?
Re: 727 question [Re: biggerredz71] #693415
05/09/10 09:33 PM
05/09/10 09:33 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If that's the case than it may still need the kick down installed.
Did he save you the instructions for the kit? Might want to ask for those.
Re: 727 question [Re: WILD BILL] #693416
05/10/10 10:22 AM
05/10/10 10:22 AM
hartsburg mo
hartsburg mo
Well I talked to my trans guy this morning and he said it was a trango tf3 kit that was put in the VB,he said running the kick down cable would make the tranny last longer.What is your alls opinion?he said I didnt have to use it.Anybody else run the tf3 kit and if so did you run a kick down?
Re: 727 question [Re: biggerredz71] #693417
05/10/10 04:02 PM
05/10/10 04:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The TF-3 gives you the option of using linkage or not, using the linkage will make the part throttle shifts less violent.
If you don't want to use the linkage just tie the lever full back.
Re: 727 question [Re: biggerredz71] #693418
05/10/10 04:52 PM
05/10/10 04:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I can`t beleive guys still use that kit.........I never had good results(and others I know) from that kit and if it was me, I`d highly consider washing my hands of that antique stuff and step up to an after market VB.
Re: 727 question [Re: Thumperdart] #693419
05/10/10 05:25 PM
05/10/10 05:25 PM
hartsburg mo
hartsburg mo
Well heres the deal,we took the trans in to have it rebuilt,told them we wanted a manual vb,bolt in sprag,solid bands etc,well it lasted 15 miles and they would not stand behind it when reverse went out.So I take it to another guy to have him fix it and when he pulled it apart it didnnt have anything it was supposed to.He said the valve body had a kit in it to make it manual,so now we have a $2000 trans , with a tf3 kit.the original shop who first did the tranny gave us a recipt that had a $300 vb and all the good stuff on it but they screwed us,time to talk to a lawyer I guess.This is a 70 Roadrunner with a new 505.I guess we should of just left the OL 4speed in,this has become a money pit.lol
Re: 727 question [Re: John_Kunkel] #693420
05/10/10 05:27 PM
05/10/10 05:27 PM
hartsburg mo
hartsburg mo
John if i wire the lever back it will be alright for street strip use?
Re: 727 question [Re: biggerredz71] #693421
05/10/10 07:07 PM
05/10/10 07:07 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
If you do that it will shift hard on the street..
Re: 727 question [Re: biggerredz71] #693422
05/10/10 07:10 PM
05/10/10 07:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yes but, it will shift w/full line pressure at all times and bang at lower speeds.........at least mine did.
Re: 727 question [Re: biggerredz71] #693423
05/10/10 07:33 PM
05/10/10 07:33 PM
Mohnton, Pa
Mohnton, Pa
Unless you have a cheap lawyer it is most likely better to cut your losses and wright the trans off to experience.
My manual valve body and I thought all manual valve bodies shift with full line pressure. I would rather have the trans shift hard at low speed then shift slow and weak under hard accelleration.This will slip things and burn things up.
I have 6-8 thousand in a transmission with one of the most highly regarded builders and it is a piece of crap. If I could get half my money back I would gladly sell it and look for something else. Many times in this hobby you get the shaft. Many Hi performance parts manufacturers and builders don't stand behind their products and services.
Re: 727 question [Re: DodgeCharger] #693424
05/10/10 07:41 PM
05/10/10 07:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I assume manual v-bodies do run full line prssure but, there`s a BIG difference between a trans-go crap shift kit and a REAL race v-body. The shift is ridiculously hard at slow speeds w/the trans-go unlike my Cheetah bad dog.
Re: 727 question [Re: DodgeCharger] #693425
05/10/10 08:05 PM
05/10/10 08:05 PM
hartsburg mo
hartsburg mo
This just suck's we've been building this car since last spring with the new 505 and auto tranny set up.My dad originally bought this car 15 years ago and always had a 440 & 4speed and we could never keep a clutch in it,so when we decided to build a stroker and I talked him into going auto with a nice stall,well we've only had this thing out a couple of times and out of nowhere reverse decided to go out.The 505 seems to run real well and my dad is pretty intimadated when he drives it.lol Im going to put the trans back in this weekend and didnt know what to do with the cable.I also have a new Prosystems carb sitting on the bench waiting to be put on.Thanks for all of your input,we've thrown alot of cash at this thing for the past year and cant seem to make it out of the garage.lol Thanks guy's
Re: 727 question [Re: biggerredz71] #693426
05/10/10 09:29 PM
05/10/10 09:29 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Sounds like a small claims court action.
Re: 727 question [Re: RobX4406] #693427
05/10/10 10:22 PM
05/10/10 10:22 PM
hartsburg mo
hartsburg mo
I told him to use my guy,but he found this shop that said they would have it done in 2 day's.I've herd stories about this shop and I Think he was trying to make payroll.Oh well my ol man spends the money I do all the wrenching.lol Rant's & Raves on craigslist works well lol
Re: 727 question [Re: biggerredz71] #693428
05/11/10 10:08 AM
05/11/10 10:08 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
It amazes me how many $ racers spend on transmissions. The 727 is a very simple piece of machinery. It takes very little in after market parts to hold up to a 10.0 3500lb vehicle. Heres the list of what works,there are upgrades and other combos but these work from my experience. Use Turbo Action manual valve body. This part alone makes life simple. I've been running them street and track for over 25 years. The low speed shift is tolerable, especially with a looser converter. Next good quality clutches and bands. Raybestoes tans work fine and are cheap. You can upgrade to Alto reds,blues,Kevlar band if you like. Use a 4 plate front drum. Use a 3.8,4.2,5.0 lever. Put 15 springs in the front drum. Use both inner and outer springs in the K.D. servo. As for the front drum if your worried about safety get a after maket drum. Get a good book such as Carl Monroes and put it together. If you have a problem ask a question. Someone will help. If you can assemble a engine you can do a trans. Very little is needed in the way of tools. In fact my 1st builds involved no special tools at all. It just took a little longer. Find your local trans wholesale house. The parts minus the drum and valve body seldom exceed $100. This combo will live for years.
Doug
