Re: 71 Challenger R/T Rear Finish Panel Color? [Re: HPMike] #692451
05/11/10 11:52 AM
05/11/10 11:52 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Original car. Definitely textured,
Is that texture like the rough surface of a T/A or AAR hood?
I just think there's very degrees of this texture.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: autoxcuda] #692452
05/11/10 12:15 PM
05/11/10 12:15 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
It's the rough texture, but I think it's all in how you spray it. I've seen some TA hoods done by a SoCal restore expert that look like spackle
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: Morty426] #692453
05/11/10 01:35 PM
05/11/10 01:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Here are some pictures I just took of my orginal tailight bezels. This is just the bezel. These were not painted with the rear trim panal on the car. And I bet painted by the facility that made/painted the tailight bezels.
Yes, they have texture. I just don't know how this compares to the original T/A AAR hood paint or the various over the counter repro organisol paints that don't seem consistant with each other.
The corner I took pictures of is covered up from sunlight and wiping/washing. I added some moisture to get some contrast to show in the pictures. Tough to get a good picture. Especially with my pocket camera.
EDIT These pictures here are not showing the same detail as the orginal picture on my computer. Sorry.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: autoxcuda] #692454
05/11/10 01:39 PM
05/11/10 01:39 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have some original 71 RT rear bezals at home. I remember them being a pretty rough paint finish. Maybe I'll post some pictures when I get home.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: Challenger 1] #692455
05/11/10 02:19 PM
05/11/10 02:19 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
Oh I have my original and you can tell it had a texture at one time.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: Morty426] #692456
05/11/10 10:56 PM
05/11/10 10:56 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
[quote
Where is this paint line? On Steve Juliano's 71 R/T sunroof car there is a black painted (tape?) little a section on the fender inside front edge of the hood gap. Is that what your are referring to?? I've never seen it anywhere else. And that car was not restored by Steve.
Morty426, do you have a picture?
I don't have the original fenders on my 71 R/T M28 car.
I'll get you a picture tonight. I have my original buckets and NOS buckets - the NOS ones are missing the tape. The tape is also on the hood trim. I don't think it is unique to being an M73 car.
Here is my original bezel. You can see the tape stops above the screw hole.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: Morty426] #692457
05/11/10 10:58 PM
05/11/10 10:58 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
here's a close up of the tape -
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: Morty426] #692458
05/11/10 11:17 PM
05/11/10 11:17 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Wow
Now I'm going to have to look at ours tomorrow.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: Morty426] #692459
05/12/10 12:09 AM
05/12/10 12:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Cool. Nice pictures. Thanks.
One of Grizzy's questions was asking the R/T and non paint scheme with wide hood molding package; hood periphery molding M28.
Does the hood periphery molding trigger any paint scheme/blackout/tape etc difference on any part front end?
I did see black paint on the painted fender on Steve Juliano's 71 Challenger sunroof car with hood periphery that was restored by Walt Downer. It was on the fender under the fender section of the hood periphery molding, right at the hood gap. Has anyone else seen that on another car??
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: autoxcuda] #692460
06/18/10 01:56 AM
06/18/10 01:56 AM
State, country, etc.
gss Offline
gss  Offline
Sorry to revive a dead thread, but what would be the proper way to restore the black paint on the trunk and quarter panel trim pieces? What paint and prep? TIA
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: gss] #692461
06/18/10 02:45 AM
06/18/10 02:45 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I just saw a metal dash frame done in Rust-Oleum Fine Textured Finish spray can paint from Walmart that Troy did. Came out pretty darn nice.
I first used this paint on my Minilite polished rims to give them a cast look. It's pretty fine for that, but the best I could come up with. Walmart had the cheapest price on this stuff.
For $6, test it and see if you like it. It's not wrinkle paint and much finer than that. Seems very close to the un-exposed end pieces of my original 71 R/T tail lite bezels.
I don't think the aluminum trunk and quarter trim or hood pieces has black that is textured??
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: gss] #692462
06/18/10 12:28 PM
06/18/10 12:28 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
Glad you brought that up - I have one NOS peice that I'll try match - would love to also here suggestions
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: Morty426] #692463
06/18/10 01:30 PM
06/18/10 01:30 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
On the bezels I have one that had the tape... I figured someone just put it on and had no idea it was original. It was dried up and cracked so I removed it, but now I know it was an rt bezel for sure.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: Silver70] #692464
06/18/10 09:29 PM
06/18/10 09:29 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
I have not seen any special paint treatment for the M28 mouldings, however, IIRC there is a separate part number for the V6X R/T stripes - they are a bit shorter at the front of the fenders.
(not unlike the current Challengers)
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: YYZ] #692465
06/21/10 09:39 AM
06/21/10 09:39 AM
Bel Air Maryland USA 21014
wmwalden Offline
wmwalden  Offline
Here is the drawings from the factory. Note the paint color in the lower right side of pic.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: YYZ] #692466
06/21/10 12:15 PM
06/21/10 12:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Thanks,
Just wondered if people have seen some original paint 1971 M28 Hood Periphery R/T and non R/T cars.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: autoxcuda] #692467
06/21/10 12:57 PM
06/21/10 12:57 PM
wmwalden Offline
wmwalden  Offline
I have had and still do have a bunch of the stuff. I just sold a NOS Center piece. The black is a semi-gloss to flat. meaning not quite flat but not to shinny as well. Like the trim black.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: wmwalden] #692468
06/21/10 03:53 PM
06/21/10 03:53 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
That drawing is for 70 - for 71 it's a lot larger area.
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: wmwalden] #692469
06/22/10 10:51 AM
06/22/10 10:51 AM
gss Offline
gss  Offline
I thought Organosol was not available? What is used today?
Re: 71 Challenger R/T Rear Finish Panel Color? [Re: gss] #692470
06/22/10 12:22 PM
06/22/10 12:22 PM
Sacramento CA
Morty426 Offline OP
Morty426  Offline OP
Sacramento CA
You can get it from Roger Gibson
