TnT last night. #692263
05/08/10 12:57 PM
05/08/10 12:57 PM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Drove the dart the 50 miles to the track last night for a few passes, 2 weeks ago it ran a 13.07 on a 1.86, this is just a very mild 360 magnum with a stock high miled short block, 3.73 gears & 2800 11" PTC converter, last outing timing was at 25* total & had a 3310 on it, bumped the timing up too 30* & installed a 650dp jetted at 70/76, the cam is a small re-ground, .477/.477 lift with .218/.218 @50 on a 112. Shifting at 5200 through the mufflers. 1st. pass was on a pro-tree, i let off just after the 1000ft. next 2 passes i ran it out. I'm in the left lane. So how did i do .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: TnT last night. [Re: joedust451] #692264
05/08/10 01:03 PM
05/08/10 01:03 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
Wow, I'd say you got it tuned just right, wish my street car would run like that!
Re: TnT last night. [Re: joedust451] #692265
05/08/10 01:11 PM
05/08/10 01:11 PM
San Diego
formula S Offline
formula S  Offline
San Diego
I think you left some on the table, bump the timing up a little to 35 deg and try it again, you might get a little more out of it.
Re: TnT last night. [Re: formula S] #692266
05/08/10 01:24 PM
05/08/10 01:24 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
These magnum heads don't really need all that timing like the LAs, the most i'll go is 32* & see how it does but thats it, i don't want detination, i'm running on 87 octane.
Re: TnT last night. [Re: joedust451] #692267
05/08/10 01:48 PM
05/08/10 01:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I bet yo would pick up more with more timing.
Re: TnT last night. [Re: Quicktree] #692268
05/08/10 03:11 PM
05/08/10 03:11 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
joe, one of the cars that i sponsor out of my shop has a magnum crate motor with one of my 4777's on it. he runs 35 total, i believe. he's jetted about like you too.
Re: TnT last night. [Re: tjmarcus1] #692269
05/08/10 03:29 PM
05/08/10 03:29 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Whats the cam specs on that crate? Mine is just a re-gring from Bullet cams, accually its the cam that was in it, if i do get out there again, i'll try more timing, but the DA i'm sure will be getting worse, you know how that goes lol, are track here is at 1650ft. I'm still trying to slap myself & see if i wake up from a dream, i'd never thought this combo would run so good, i'm sure theres a tenth or 2 left in it somewere (maybe), i was hopeing for a 12.99 & i would have been satisfied, but i was told by many it wasn't in the cards with this mild combo.
Re: TnT last night. [Re: joedust451] #692270
05/08/10 03:34 PM
05/08/10 03:34 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
what ever came in the 360/390hp. it looks like your car is doing well like it is. i mean, an 8.06 in the 1/8? not too bad indeed!!!!
Re: TnT last night. [Re: tjmarcus1] #692271
05/08/10 03:51 PM
05/08/10 03:51 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Heres the complete combo.
71 Swinger
No AC/PS or PBs
All steel (including bumpers/hood)
95 360 magnum, stock short block.
RHS heads from Hughes engines. (baseline)
Crosswind RPM Airgap.
Summit headers, 2.1/4" exhaust with summit turbos.
Mallory 6AL, MSD dist., 10* int., 30* total all in by 2300 rpm. 17 inches. vacuum.
spooled 3.73s, 255/60/15 MT DRs, stock springs (clamped), longer rear shocks (73 truck), -3 pinion angle, Home made SFCs.
383man [Re: joedust451] #692272
05/08/10 04:21 PM
05/08/10 04:21 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Looks like the interior of my sons 72 Dart. Joe were you still in it on the 12.58 ?? I mean 12.50's @ 104 mph is a very good et for the mph unless you lifted and if you did it has more in it. Very good tune you did on her. Ron
Re: 383man [Re: 383man] #692273
05/08/10 06:22 PM
05/08/10 06:22 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Joe I can see the grin on your face all the way from Joplin. Sorry I couldn't make it. Our service mgr. took a vacation so I couldn't get off work early. Jim
Re: 383man [Re: rt66jim] #692274
05/09/10 01:06 AM
05/09/10 01:06 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
Ron, it was full passes on the last 2 runs, it was only gaining 19 mph between the 1/8 too 1/4, i'm sure if i put alittle bigger carb/more timing & release some exhaust it would have another 2 tenths & maybe 2 mph, Even though the mph seems alittle low for the ET its not, i met a guy last year running a 63 nova with a very mild 350, he was running 12.0s @ 106-107, his 60ft times were really good, they were in the 1.57 range.
Jim, sorry you couldn't make it out, the place was packed, it was a fun night.
Re: 383man [Re: joedust451] #692275
05/09/10 10:39 AM
05/09/10 10:39 AM
Clinton Twp, Michigan
DerickS Offline
DerickS  Offline
Great job Great running car
Re: 383man [Re: DerickS] #692276
05/09/10 11:29 AM
05/09/10 11:29 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
