Page 17 of 19 1 2 15 16 17 18 19
Re: Pics of your lowered 72-93 Dodge trucks [Re: BulletBob] #691631
01/19/15 05:45 PM
01/19/15 05:45 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
So how did you do the back?
Moparlee
Re: Pics of your lowered 72-93 Dodge trucks [Re: Robbins] #691632
01/19/15 11:41 PM
01/19/15 11:41 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Axle flip with the rear spring hangers moved up on the frame
Re: Pics of your lowered 72-93 Dodge trucks [Re: BulletBob] #691633
01/20/15 08:44 PM
01/20/15 08:44 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
What happen to the box on the white Truck?
Re: Pics of your lowered 72-93 Dodge trucks [Re: Webster] #691634
01/21/15 05:07 AM
01/21/15 05:07 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Tornado A tree fell through the garage where it sat since new until 6 years
I had offered to buy it 5 years before Belonged to a friends Dad & my Bro called me one day & said "You owe me $600" "You just bought a white ShortBed with a bad bedside"
I just went & picked it up this past November
It sat for 6 years at my Bro's house inside
Re: Pics of your lowered 72-93 Dodge trucks [Re: BulletBob] #691635
01/21/15 12:14 PM
01/21/15 12:14 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Did you turn the front one up side down...and did you just cut the access off on the back? Sorry...couldn't talk you into more pics could I. I'm getting ready to lower the old RC I do believe.
Moparlee
Re: Pics of your lowered 72-93 Dodge trucks [Re: Robbins] #691636
01/21/15 02:08 PM
01/21/15 02:08 PM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
Bob,
Truck looks great! On the front, did you cut any coils or just used van LCA with unmodified coils. Thanks!
Re: Pics of your lowered 72-93 Dodge trucks [Re: Dave W] #691637
01/21/15 07:42 PM
01/21/15 07:42 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Bob,
I used the stock springs with Van LCAs
Here's some better pics
Re: Pics of your lowered 72-93 Dodge trucks [Re: BulletBob] #691638
01/21/15 08:23 PM
01/21/15 08:23 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Lee, my experience with the RamCharger was doing an axle flip & van LCAs with stock springs & it needed Dak spindles to level out or the rear spring hanger moved down roughly 2" The drop was 5 1/2-6"
I left the front hangers alone
In this pic it has matching tires all the way around
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #691639
01/21/15 11:51 PM
01/21/15 11:51 PM
Texas
ralph67 Offline
ralph67  Offline
Texas
new to all of this so if it is wrong ill learn.
thanks to rapidmaximas for all the help
Re: Pics of your lowered 72-93 Dodge trucks [Re: ralph67] #691640
01/22/15 11:44 AM
01/22/15 11:44 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Looks Good
Re: Pics of your lowered 72-93 Dodge trucks [Re: ralph67] #691641
01/22/15 11:52 AM
01/22/15 11:52 AM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
Nice ride.
Re: Pics of your lowered 72-93 Dodge trucks [Re: 727builder] #691642
01/24/15 06:42 PM
01/24/15 06:42 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Finally got to do a little work om my 79 step-side street/strip project. Sat engine and trans down in it today. And to my amazement TTI 2" A-body under chassis headers fit like a glove. Pass required no work at all. Driver side i moved the Proportioning Valve and ground out a small area on the top of the frame rail for #7 header tube to clear.
How about some under body pics to show where the collectors are sitting.?
Re: Pics of your lowered 72-93 Dodge trucks [Re: Uberpube] #691643
01/28/15 10:41 PM
01/28/15 10:41 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
What #TTI
Another member here did the same but didn't give the # or somehow I missed it
BTW here's a better shot from the street bedside & all
Re: Pics of your lowered 72-93 Dodge trucks [Re: BulletBob] #691644
02/05/15 03:45 PM
02/05/15 03:45 PM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
I thought I would pop into Moparts. I've been away from cars and forums for a while. A lack of hobby funds takes the wind out of your sails for sure. I'm researching a plan for the new drivetrain. I'm looking at building up a 400 based stroker.
Re: Pics of your lowered 72-93 Dodge trucks [Re: Kevin I] #691645
02/05/15 05:17 PM
02/05/15 05:17 PM
Iowa
76dodgeboy Offline OP
Iowa
Why not just stroke the 440?
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #691646
02/05/15 05:25 PM
02/05/15 05:25 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The 400 gets bigger quicker 4.32 bore
Re: Pics of your lowered 72-93 Dodge trucks [Re: BulletBob] #691647
02/10/15 04:51 PM
02/10/15 04:51 PM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
I was looking at that for a while and talked to muscle motors about it. The 451 (400 block with a 440 crank) makes good power and is cheapest to build, assuming you have good used parts. The 472 (or something close to that) was the best bang for the buck. The 500 needs a lot of mods and external oiling, but is a beast. I've dealt with MM a few times and found them both helpful and experienced. Good luck, keep us up on it. Wish you were closer to WV I could get you started with my abandoned parts stash.
Re: Pics of your lowered 72-93 Dodge trucks [Re: Kevin I] #691648
02/10/15 09:03 PM
02/10/15 09:03 PM
Pennsylvania
Red 79 Offline
Red 79  Offline
Pennsylvania
Sure is a sweet lookin truck
Re: Pics of your lowered 72-93 Dodge trucks [Re: wedgeheaded] #691649
02/13/15 12:40 AM
02/13/15 12:40 AM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
Tell me what you have. Maybe we can work on something.
Re: Pics of your lowered 72-93 Dodge trucks [Re: 727builder] #691650
02/13/15 11:34 AM
02/13/15 11:34 AM
TN
JS29R0B Offline
JS29R0B  Offline
TN
Here in my 78 tubbed 4 link twin turbo diesel
