Page 4 of 19 1 2 3 4 5 6 18 19
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #691371
09/18/10 01:32 PM
09/18/10 01:32 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Thats with the bags dumped. With the bags inflated it is a 4x4.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Pics of your lowered 72-93 Dodge trucks [Re: hp383] #691372
09/18/10 07:43 PM
09/18/10 07:43 PM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
most of you saw mine but I never posted pics here
Get Real Get Mopar
Re: Pics of your lowered 72-93 Dodge trucks [Re: 1moparman] #691373
09/18/10 07:45 PM
09/18/10 07:45 PM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
another
Get Real Get Mopar
Re: Pics of your lowered 72-93 Dodge trucks [Re: 1moparman] #691374
09/18/10 09:11 PM
09/18/10 09:11 PM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
1moparman, that truck looks great. I like the stance on it. How did you lower it?
Re: Pics of your lowered 72-93 Dodge trucks [Re: Kevin I] #691375
09/18/10 09:34 PM
09/18/10 09:34 PM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
on the rear put the axle on top of the leafs and on the front van lca with 1/2 coil cut to match the rear. I havr brand new lowering shackles I bought but didn't use if someone's going that method
Get Real Get Mopar
Re: Pics of your lowered 72-93 Dodge trucks [Re: 1moparman] #691376
09/18/10 09:53 PM
09/18/10 09:53 PM
Perryopolis PA
turbododgepirate Offline
Perryopolis PA
Lots of awesome trucks. Now a question for you. For the guys with WIDE rear tires. WITHOUT tubbing it, and with a stock rear axle what is the widest rim (and backspacing) and tires you can fit?? I am considering tubbing my truck to add some fatties out back, but dont know if im going to go generic tubs from summit, or try to extend the factory wells. Thanks!!
Re: Pics of your lowered 72-93 Dodge trucks [Re: turbododgepirate] #691377
09/18/10 10:47 PM
09/18/10 10:47 PM
Mena Arkansas
DTM_Motorsports Offline
Mena Arkansas
here is mine
Might go a little lower in the back, but
you get the idea, just trying to get my ideas for
paint in order too
This is the color it was, thinking about going
back to yellow with a stripe down side
I'll post a picture next of how I want it to turn out
Re: Pics of your lowered 72-93 Dodge trucks [Re: DTM_Motorsports] #691378
09/18/10 10:49 PM
09/18/10 10:49 PM
Mena Arkansas
Mena Arkansas
Ok, Mine is the yellow one just above this post
It is NOW just primer grey it used to be yellow
I'm thinking about going back with this paint
scheme just in yellow and black instead of white and black
This is NOT my truck, and my hood will not be black
but other than that will be same, just yellow with a black stripe
Although the white is starting to grow on me
Re: Pics of your lowered 72-93 Dodge trucks [Re: DTM_Motorsports] #691379
09/18/10 11:04 PM
09/18/10 11:04 PM
Mena Arkansas
Mena Arkansas
Here is what it looks like NOW
Re: Pics of your lowered 72-93 Dodge trucks [Re: DTM_Motorsports] #691380
09/18/10 11:14 PM
09/18/10 11:14 PM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
here is mine
paint in order too
yellow with a black bumble bee stripe at the rear would look killer on that truck
Get Real Get Mopar
Re: Pics of your lowered 72-93 Dodge trucks [Re: turbododgepirate] #691381
09/18/10 11:21 PM
09/18/10 11:21 PM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
i'd say 275 60 15 would fit and probably 295's with the right off set rim and of coarse it really would depend on how low your truck is but jfyi I have some 15x10 with 275 60 15 the ofset was good for my stepside but when I tried to put them on my 80 after I lowered it they wouldn't fit they stuck out too far on the standard bed
Get Real Get Mopar
Re: Pics of your lowered 72-93 Dodge trucks [Re: 1moparman] #691382
09/18/10 11:33 PM
09/18/10 11:33 PM
Mena Arkansas
Mena Arkansas
Yeah it's been $ different colors including
original paint, was maroon and white
then gloss black, then yellow, then flat black
now primer grey until next paint job
Wish I could decide between the yellow or white
Love the stripe though
Heres what it looked like black
Re: Pics of your lowered 72-93 Dodge trucks [Re: DTM_Motorsports] #691383
09/18/10 11:34 PM
09/18/10 11:34 PM
Mena Arkansas
Mena Arkansas
Here it is when it was flat black
Re: Pics of your lowered 72-93 Dodge trucks [Re: DTM_Motorsports] #691384
09/18/10 11:35 PM
09/18/10 11:35 PM
Mena Arkansas
Mena Arkansas
Here is how it all started LOL
Re: Pics of your lowered 72-93 Dodge trucks [Re: DTM_Motorsports] #691385
09/18/10 11:59 PM
09/18/10 11:59 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
That Trucks been around!
Re: Pics of your lowered 72-93 Dodge trucks [Re: Webster] #691386
09/19/10 12:16 AM
09/19/10 12:16 AM
Mena Arkansas
Mena Arkansas
Just slightly
Re: Pics of your lowered 72-93 Dodge trucks [Re: DTM_Motorsports] #691387
09/19/10 12:40 AM
09/19/10 12:40 AM
MO
C_Notch Offline
C_Notch  Offline
MO
my '84
Re: Pics of your lowered 72-93 Dodge trucks [Re: C_Notch] #691388
09/19/10 02:20 AM
09/19/10 02:20 AM
Iowa
76dodgeboy Offline OP
Iowa
my '84
Those 16" rims? What size tire. Looks good
Re: Pics of your lowered 72-93 Dodge trucks [Re: 76dodgeboy] #691389
09/19/10 02:58 PM
09/19/10 02:58 PM
MO
C_Notch Offline
C_Notch  Offline
MO
my '84
Wheels are 17" off Ram
Tires front 255/5517 rear 285/60/17
thanks
Re: Pics of your lowered 72-93 Dodge trucks [Re: C_Notch] #691390
09/19/10 05:00 PM
09/19/10 05:00 PM
Iowa
Iowa
I wanted to say 17 but wasnt sure. Looks good Did you swap the bolt pattern to 5x4.5?
