Re: Pics of your lowered 72-93 Dodge trucks
[Re: 76dodgeboy]
#691371
09/18/10 12:32 PM
09/18/10 12:32 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Thats with the bags dumped. With the bags inflated it is a 4x4.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#691372
09/18/10 06:43 PM
09/18/10 06:43 PM
Posts: 705 lakeside ca
1moparman
lakeside ca
most of you saw mine but I never posted pics here
Get Real Get Mopar
[Re: Kevin I]
#691375
09/18/10 08:34 PM
09/18/10 08:34 PM
1moparman
lakeside ca
on the rear put the axle on top of the leafs and on the front van lca with 1/2 coil cut to match the rear. I havr brand new lowering shackles I bought but didn't use if someone's going that method
Get Real Get Mopar
[Re: turbododgepirate]
#691377
09/18/10 09:47 PM
09/18/10 09:47 PM
Posts: 123 Mena Arkansas
DTM_Motorsports
Mena Arkansas
here is mine Might go a little lower in the back, but you get the idea, just trying to get my ideas for paint in order too This is the color it was, thinking about going back to yellow with a stripe down side I'll post a picture next of how I want it to turn out
[Re: DTM_Motorsports]
#691378
09/18/10 09:49 PM
09/18/10 09:49 PM
DTM_Motorsports
Mena Arkansas
Ok, Mine is the yellow one just above this post
It is NOW just primer grey it used to be yellow
I'm thinking about going back with this paint scheme just in yellow and black instead of white and black
This is NOT my truck, and my hood will not be black
but other than that will be same, just yellow with a black stripe
Although the white is starting to grow on me
#691387
09/18/10 11:40 PM
09/18/10 11:40 PM
Posts: 84 MO
C_Notch
MO
[Re: C_Notch]
#691388
09/19/10 01:20 AM
09/19/10 01:20 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
my '84
Those 16" rims? What size tire. Looks good
[Re: 76dodgeboy]
#691389
09/19/10 01:58 PM
09/19/10 01:58 PM
Posts: 84 MO
C_Notch
MO
my '84
Wheels are 17" off Ram Tires front 255/5517 rear 285/60/17 thanks
[Re: C_Notch]
#691390
09/19/10 04:00 PM
09/19/10 04:00 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
I wanted to say 17 but wasnt sure. Looks good Did you swap the bolt pattern to 5x4.5?
