Drum to disc swap on 73 challenger #691303
05/07/10 06:13 PM
05/07/10 06:13 PM
ohio
moparinator Offline OP
ohio
I have recently switched from drum to disc front brakes on my 73 challenger. I also put on a new dual reservoir master cylinder. The problem that I am having is that I have no front brakes. They bleed out fine with no air. The rear drums are good also.
After I pump the pedal up I can hear brake fluid squirt back into the master cylinder from the front brakes. All lines are tight and nothing is leaking.
I read somewhere that I might have to change the proportioning valve. Is this true? If not, what could the problem be?
Thanks for everyones time.
Re: Drum to disc swap on 73 challenger [Re: moparinator] #691304
05/07/10 06:18 PM
05/07/10 06:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
There is no PP valve on drums.You will need one.Thats not the problem.Did you bleed the master?That and make sure the caliper bleeders are facing up.You can bleed gallons thru and not have brakes.Dont ask how I know.Rocky
Chrysler Firepower
Re: Drum to disc swap on 73 challenger [Re: therocks] #691305
05/07/10 06:31 PM
05/07/10 06:31 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought some time in 73 or 74 all E-body got disk brakes standard?
Re: Drum to disc swap on 73 challenger [Re: autoxcuda] #691306
05/07/10 06:37 PM
05/07/10 06:37 PM
IN
ahy Offline
ahy  Offline
IN
Check to make sure the bleeder valves are at the top of caliper. If they are at the bottom, there will be a big air pocket stuck in the caliper and you won't have brakes. The fix is usually to switch calipers left to right.
Re: Drum to disc swap on 73 challenger [Re: ahy] #691307
05/07/10 06:38 PM
05/07/10 06:38 PM
NJ
440challenger Offline
NJ
73+ all disc brakes. Someone must of scabbed them off the car and threw drum stuff on
Re: Drum to disc swap on 73 challenger [Re: 440challenger] #691308
05/07/10 06:46 PM
05/07/10 06:46 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That's what's got me worried. Wonder what was taken off and what was "thrown" back on. Might need to evaluate every part in that brake system to see where it came from.
Re: Drum to disc swap on 73 challenger [Re: autoxcuda] #691309
05/07/10 09:37 PM
05/07/10 09:37 PM
ohio
ohio
I flipped the calipers and everything worked out great. I just got home from the first shake down cruise without breaking down, so I'm happy.
I knew I had them on wrong, but I was concerned with the brake line hitting the control arm. This brake swap has taken me a week and 2 sets of calipers and 2 master cylinders. Not to mention the gallons of brake fluid. The first ones were off a coronet and did not work out as everyone probably already knows.
I did not think that calipers knew what side was up. Now I know.
I should have looked into this brake swap a little more than just jumping into it. I am definitly getting a mopar education though.
Thanks to everyone for helping me out. I really appreciate it.
