What are the NHRA rules for attaching seat to roll bar? #688424
05/04/10 05:33 PM
05/04/10 05:33 PM
Confusion
Dodger440 Offline OP
Confusion
Are there any specific NHRA rules for how to attach the drivers seat back to the roll bar? The car will run 9.60, so it will have to be certified. Just want to make sure I do it right the first time. Thanks.
Re: What are the NHRA rules for attaching seat to roll bar? [Re: Dodger440] #688425
05/04/10 06:43 PM
05/04/10 06:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My seat does NOT attach to the cross bar bar it is real
close to it(might even touch when I am in it) and my
car is certed to 8.50 now(was 7.50 with the same set up)
Re: What are the NHRA rules for attaching seat to roll bar? [Re: MR_P_BODY] #688426
05/04/10 06:52 PM
05/04/10 06:52 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
2010 NHRA
6:2 UPHOLSTERY, SEATS
The driver’s seat of any car in competition must be constructed,
braced, mounted, and upholstered to provide full back and shoulder
support. The driver’s seat must be supported on the bottom and
back by the frame or crossmember.
Except as noted in SFI
Specifications, seats must be bolted with four bolts (and nuts and
washers) on the bottom and one bolt in the rear into crossbar; all
bolts must go into frame or crossbraces. Ball-lock pins for seat
attachment prohibited in all classes. All seats must be upholstered,
or as noted under Class or SFI Requirements. All front-engine,
open-bodied, supercharged or turbocharged (gasoline or methanol)
cars running 7.49 seconds and quicker must have a flameretardant-
material-upholstered seat.
Properly braced, framed, supported, and constructed seats of
aluminum, fiberglass, carbon fiber, or double-layer poly
(accessory seats) permitted. Single-layer fiberglass seats must
have steel tube framework, 1/2-inch-minimum O.D., for support.
Aftermarket aluminum seats must have reinforced head rest.
Re: What are the NHRA rules for attaching seat to roll bar? [Re: MR_P_BODY] #688427
05/04/10 06:58 PM
05/04/10 06:58 PM
ProStDodge Offline
ProStDodge  Offline
Chassis certification is for the cage only. So it is possible to have an observant tech catch you on the lack of a "proper" attachment.
Re: What are the NHRA rules for attaching seat to roll bar? [Re: ProStDodge] #688428
05/04/10 07:45 PM
05/04/10 07:45 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Directly from the rule book:
Specifications, seats must be bolted with 4 bolts and nuts and washers on the bottom and one bolt in the rear into the crossbar. All bolts must go into frame or crossbraces.
09 rulebook, section 6:2 Page 271, gen regs
SRT DEMON ONE SEAT
Re: What are the NHRA rules for attaching seat to roll bar? [Re: ProStDodge] #688429
05/04/10 09:12 PM
05/04/10 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well I guess I better look at putting a bolt in
some where back there... has never been a problem
for years now.... thanks for the info guys
Re: What are the NHRA rules for attaching seat to roll bar? [Re: MR_P_BODY] #688430
05/04/10 09:47 PM
05/04/10 09:47 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
How is that possible?
My brother is 6'1" and I am 5'5"
we obviously can't keep the seat in the same
position.
Re: What are the NHRA rules for attaching seat to roll bar? [Re: demon440] #688431
05/04/10 09:51 PM
05/04/10 09:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
position.
You could have a tube/rod mounted to the seat back
and a larger tube that the other tube/bar slides through
and different holes that you could put a bolt through
when you slide the seat
Re: What are the NHRA rules for attaching seat to roll bar? [Re: demon440] #688432
05/04/10 09:54 PM
05/04/10 09:54 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
mine has a tube welded to the roll bar..
and a slip tube welded to a braket that bolts to back of seat..
i drilled holes..and a clevis and cotterpin.
hold it in place...for adjustment.
i can move it about 4" fore or aft..if i need to.
fwiw
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: What are the NHRA rules for attaching seat to roll bar? [Re: cheapstreetdustr] #688433
05/04/10 10:18 PM
05/04/10 10:18 PM
Confusion
Confusion
Thanks guys! The NHRA written rule seems vague on the rear brace, so I guess as long as I have something with at least 1 bolt going to the seat I should be fine.
Re: What are the NHRA rules for attaching seat to roll bar? [Re: cheapstreetdustr] #688434
05/04/10 10:19 PM
05/04/10 10:19 PM
Missouri
Challenger Offline
Challenger  Offline
Missouri
What about some of the stockers that have stock interior? Ive always wondered what they do?
Re: What are the NHRA rules for attaching seat to roll bar? [Re: Challenger] #688435
05/04/10 10:35 PM
05/04/10 10:35 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
I have race buckets in my car and they are against the cage and I have takin it to Gateway / the most picky tech in the country imo . He has never said a word to me about it.
www.sikosracing.net Heads up Drag racing
Re: What are the NHRA rules for attaching seat to roll bar? [Re: demon440] #688436
05/04/10 10:42 PM
05/04/10 10:42 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
position.
Jegs and Summit sell sliding tracks and adjustable
seat back braces I have them in my car. Not certified but no problem with tech.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: What are the NHRA rules for attaching seat to roll bar? [Re: DragDart360] #688437
05/04/10 11:09 PM
05/04/10 11:09 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I also thought it had to be
a certain distance from the bar?
