Re: What are the NHRA rules for attaching seat to roll bar?
[Re: Dodger440]
#688425
05/04/10 06:43 PM
05/04/10 06:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Are there any specific NHRA rules for how to attach the drivers seat back to the roll bar? The car will run 9.60, so it will have to be certified. Just want to make sure I do it right the first time. Thanks.
My seat does NOT attach to the cross bar bar it is real close to it(might even touch when I am in it) and my car is certed to 8.50 now(was 7.50 with the same set up)
[Re: MR_P_BODY]
#688426
05/04/10 06:52 PM
05/04/10 06:52 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
2010 NHRA 6:2 UPHOLSTERY, SEATS The driver’s seat of any car in competition must be constructed, braced, mounted, and upholstered to provide full back and shoulder support. The driver’s seat must be supported on the bottom and back by the frame or crossmember. Except as noted in SFI Specifications, seats must be bolted with four bolts (and nuts and washers) on the bottom and one bolt in the rear into crossbar; all bolts must go into frame or crossbraces. Ball-lock pins for seat attachment prohibited in all classes. All seats must be upholstered, or as noted under Class or SFI Requirements. All front-engine, open-bodied, supercharged or turbocharged (gasoline or methanol) cars running 7.49 seconds and quicker must have a flameretardant- material-upholstered seat. Properly braced, framed, supported, and constructed seats of aluminum, fiberglass, carbon fiber, or double-layer poly (accessory seats) permitted. Single-layer fiberglass seats must have steel tube framework, 1/2-inch-minimum O.D., for support. Aftermarket aluminum seats must have reinforced head rest.
[Re: MR_P_BODY]
#688427
05/04/10 06:58 PM
05/04/10 06:58 PM
ProStDodge
Chassis certification is for the cage only. So it is possible to have an observant tech catch you on the lack of a "proper" attachment.
[Re: ProStDodge]
#688428
05/04/10 07:45 PM
05/04/10 07:45 PM
Posts: 1,880 USA
Ron Silva
USA
Directly from the rule book:
Specifications, seats must be bolted with 4 bolts and nuts and washers on the bottom and one bolt in the rear into the crossbar. All bolts must go into frame or crossbraces.
09 rulebook, section 6:2 Page 271, gen regs
SRT DEMON ONE SEAT
[Re: ProStDodge]
#688429
05/04/10 09:12 PM
05/04/10 09:12 PM
MR_P_BODY
Well I guess I better look at putting a bolt in some where back there... has never been a problem for years now.... thanks for the info guys
[Re: MR_P_BODY]
#688430
05/04/10 09:47 PM
05/04/10 09:47 PM
Posts: 1,414 Stow ,Ohio
demon440
Stow ,Ohio
How is that possible? My brother is 6'1" and I am 5'5" we obviously can't keep the seat in the same position.
[Re: demon440]
#688431
05/04/10 09:51 PM
05/04/10 09:51 PM
MR_P_BODY
You could have a tube/rod mounted to the seat back and a larger tube that the other tube/bar slides through and different holes that you could put a bolt through when you slide the seat
[Re: demon440]
#688432
05/04/10 09:54 PM
05/04/10 09:54 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
mine has a tube welded to the roll bar.. and a slip tube welded to a braket that bolts to back of seat.. i drilled holes..and a clevis and cotterpin. hold it in place...for adjustment. i can move it about 4" fore or aft..if i need to. fwiw cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
