Re: Hemi Guys----Stroke/Rod Question???
[Re: Cab_Burge]
#685881
05/01/10 08:57 PM
05/01/10 08:57 PM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
4.25 stroke and a 7.100 long rod Especially a blower motor the last blown 426 hemi motor I built I used a 4.375 stroke with a 7.100 long rod and a 4.255 bore Motor made 924 HP at 7300 RPM with 7 lbs boost on CA pump gas
Ditto, but if he already has the pistons, it might not fit....Love the bob weights on the 7.1 rods with chevy journals....So nice and light.
Post deleted by Defbob
[Re: NitroFixx]
#685883
05/02/10 04:16 AM
05/02/10 04:16 AM
#685884
05/02/10 05:46 AM
05/02/10 05:46 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Go with the rod that will give you the deck height you need. You have a difference of .050 between the two combinations, which will change the compression. The 4.15 stroke 7.86 combo will be .050 higher than the 4.25 stroke 6.76 combo.
