An interesting Mopar trivia question - can YOU answer? #685176
05/01/10 05:01 AM
05/01/10 05:01 AM
New Jersey
Alan Offline OP
Alan  Offline OP
New Jersey
I only recently learned about this one... and then actually picked up an 18-spline A-833 that confirms that this is possible:
My tranny has NO serial number... the boss where it would normally be stamped is completely blank... moreover, this boss has not even been machined smooth - it has the same cast sort of surface as the rest of the iron case.
~ How can this be...?
Let's see how many guesses it takes before we have a winner with the correct answer - which I promise is the gospel truth.
- Alan
Re: An interesting Mopar trivia question - can YOU answer? [Re: Alan] #685177
05/01/10 05:14 AM
05/01/10 05:14 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Transmission from a '68 model year vehicle?
Re: An interesting Mopar trivia question - can YOU answer? [Re: DoctorDiff] #685178
05/01/10 06:43 AM
05/01/10 06:43 AM
New Jersey
Alan Offline OP
Alan  Offline OP
New Jersey
Nope. - why'68...? you can have a numbers matching 1968 car, right...?
- Alan Moderator Emeritus ~ Soon to unveil the world's only '69 Road Runner 440 R/T... "A fantasy car that never existed, but could have."
Re: An interesting Mopar trivia question - can YOU answer? [Re: Alan] #685179
05/01/10 06:50 AM
05/01/10 06:50 AM
TN
'84 D150 Shorty Offline
Pickup Man
Pickup Man
TN
is it an A833 from a GM rather than a Chrysler?
Re: An interesting Mopar trivia question - can YOU answer? [Re: '84 D150 Shorty] #685180
05/01/10 07:20 AM
05/01/10 07:20 AM
New Jersey
Alan Offline OP
Alan  Offline OP
New Jersey
Wrong again... and I do not think GM ever used New Process trannys, did they...?
I should state that this is just your typical, production Hemi 4-speed - nothing otherwise unusual about it - and the situation could just as likely involve a 23-spline, automatic 727 or 904, etc. The reason for it being a blank drive train piece is not specific that this one happens to be an 18-spline (obviously, it's from somewhere between 1968 and,mmmmmmm, 1974(?) - I'm not sure when Chrysler bailed on New Process - anybody know when they did ...?
Re: An interesting Mopar trivia question - can YOU answer? [Re: Alan] #685181
05/01/10 07:50 AM
05/01/10 07:50 AM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
GM light duty pickups used the 833OD in the eighties. The trans was modified to bolt directly into truck with GM bolt pattern, spline count, tailshaft length, etc.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: An interesting Mopar trivia question - can YOU answer? [Re: Alan] #685182
05/01/10 07:57 AM
05/01/10 07:57 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
It was an over the counter transmission. Probably warrantee replacement.
Re: An interesting Mopar trivia question - can YOU answer? [Re: Commando1] #685183
05/01/10 10:22 AM
05/01/10 10:22 AM
New Jersey
Alan Offline OP
Alan  Offline OP
New Jersey
And we have a winner...! That's correct, warranty replacement from the factory -let's say you blew the snot out of your trans somehow & the dealer conceeded you a new transmission - this is how it would have come from the assembly plant, no machining, no smooth boss, and certainly no serial number - I wonder if you would have been able to get them to knock the new unit apart so the original main case could be used - oh wait -that's right... nobody gave two hoots about "numbers matching" back then, until the Corvette types applied it to our hobby. Thanks again for doing that, Galen...
Re: An interesting Mopar trivia question - can YOU answer? [Re: Alan] #685184
05/01/10 10:35 AM
05/01/10 10:35 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Mine has no partial VIN but still has the date code and plant numbers. So are you saying that an over the counter trans had no numbers at all in that spot???
Re: An interesting Mopar trivia question - can YOU answer? [Re: Alan] #685185
05/01/10 11:51 AM
05/01/10 11:51 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Interestingly, GM used New Process A-833 OD transmissions in 2wd and 4wd pickups. Some Pontiac cars used Ford Toploader 4 speeds.
Re: An interesting Mopar trivia question - can YOU answer? [Re: Finoke] #685186
05/01/10 12:04 PM
05/01/10 12:04 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
It sounds more likely that someone replaced the case with an over the counter case. A complete over the counter transmission would have PP883 the assembly date and the sequence number stamped on the pad.
Re: An interesting Mopar trivia question - can YOU answer? [Re: Snoopy] #685187
05/01/10 12:06 PM
05/01/10 12:06 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
67 trans
Re: An interesting Mopar trivia question - can YOU answer? [Re: ScottSmith_Harms] #685188
05/01/10 12:42 PM
05/01/10 12:42 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
67 trans
'67 trans or any "trans assy" should still have the stamped assembly info & NO VIN# - "PP833 XXXX XXXX"
"over-the-counter" main case
Re: An interesting Mopar trivia question - can YOU answer? [Re: 6bblgt] #685189
05/01/10 05:39 PM
05/01/10 05:39 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
A '67 wouldn't have the raised boss, machined or not, and I agree that a replacement trans would have the PP833 stamping.
Gotta be a parts room replacement case.
Re: An interesting Mopar trivia question - can YOU answer? [Re: John_Kunkel] #685190
05/01/10 06:13 PM
05/01/10 06:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Actually John some later 67 transmissins did have the raised pad.
Re: An interesting Mopar trivia question - can YOU answer? [Re: ScottSmith_Harms] #685191
05/01/10 07:11 PM
05/01/10 07:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Come to think of it , New Process made the transfer case assys found in a lot of GM trucks; my plow truck has some Mopar in it! Philco, a division of Ford, made the radios for Mopars of the '50s. AMC used parts from everyone at one time or another.
Re: An interesting Mopar trivia question - can YOU answer? [Re: topside] #685192
05/02/10 07:47 AM
05/02/10 07:47 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Buick used Ford 3 speeds in GS's until 1970 I think. My '68 had one.
Re: An interesting Mopar trivia question - can YOU answer? [Re: slantzilla] #685193
05/02/10 08:45 AM
05/02/10 08:45 AM
New York
tt455 Offline
tt455  Offline
New York
No that is not true.Yours must have been changed.
Re: An interesting Mopar trivia question - can YOU answer? [Re: tt455] #685194
05/02/10 11:22 AM
05/02/10 11:22 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Not only did the last 18-spline that I sold NOT have the boss, it also used the 307 front bearing. As I understand it, it was a 66 trans (but may have been a 67).
Re: An interesting Mopar trivia question - can YOU answer? [Re: Alan] #685195
05/02/10 12:19 PM
05/02/10 12:19 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Here's your answer......
New Process Gear, a division of Magna Powertrain, was a joint-venture automobile transmission company set up by General Motors and the Chrysler Corporation in February 1990. It was 64% owned by DaimlerChrysler and 36% owned by GM until February 2002, when General Motors sold its stake in the company to DaimlerChrysler. Magna International purchased 80% of the company, under the holding name "New Process Gear", from DaimlerChrysler on September 29, 2004 and continues to operate it. As of 2007, Magna owns 80% of the plant.
New Venture Gear inherited Chrysler's New Process Gear Syracuse, New York plant and GM's Muncie, Indiana transmission plant. The New Process plant was renamed to the "New Process Gear Division" of New Venture Gear. New Venture operates a similar operation in Roitzsch, Germany. The Muncie plant was reverted to GM control. The name of this GM Plant was changed to "Manual Transmissions Of Muncie". It closed its doors in mid 2006, and was turned over to Delaware County, IN. The plant was soon demolished after the turnover to Delaware County, IN. Magna, after two rejections of concessions by the union, has also announced its intent to close the Syracuse plant.
New Process Gear itself has been in business since 1888.
