Re: 318 stunble
[Re: '84 D150 Shorty]
#684169
04/30/10 12:28 AM
04/30/10 12:28 AM
RapidRobert
check for an immediate squirt of gas when you move the throttle & I'm assuming it's warmed up/choke off as inadequate choke closing can do it
Re: 318 stunble
[Re: RapidRobert]
#684170
04/30/10 12:39 AM
04/30/10 12:39 AM
Posts: 738 TN
'84 D150 Shorty
Pickup Man
Pickup Man
TN
k, i just checked that, and didnt see gas squirting in. a little bit of fuel is going, but i should be able to see a visible squirt of fuel goin in right? if so, what would cause that?
Re: 318 stunble
#684171
04/30/10 12:42 AM
04/30/10 12:42 AM
RapidRobert
take the top off and check the acclerator plunger neoprene cup for rips/tears & if good check the float level (good idea anyway as it's easy and you have the top off)
Re: 318 stunble
#684175
04/30/10 02:42 AM
04/30/10 02:42 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
I'm no carburetor expert, but here's my thoughts. With no visible fuel squirt when you hit the accelerator, that means your accelerator pump is not working properly. Running with the choke partially closed will give you more fuel, so the accelerator pump issue will not be noticeable - you're covering up the lack of an accelerator pump squirt by introducing more fuel into the system with the choke. So, we need to determine why your accelerator pump is not squirting.
On my Holley, when you hit the accelerator, the accelerator pump cam pushes on a lever, which then pushes on the accelerator pump diaphram, which forces fuel through a passage and out of the squirter. A spring inside the accelerator pump bowl forces the diaphram back when the accelerator goes back to idle position. If the lever is sticking, the diaphram will not return, and the accelerator pump cam can move all it wants but it won't be moving the lever (since it's stuck), and you won't get a squirt. The same thing would probably happen if the spring behind the diaphram was broken - it wouldn't return the diaphram, and you would get no squirt. You may also have a plugged passage to the squirter, or a plugged squirter, or even a wiped lobe on the accelerator pump cam.
The way your carb creates the squirt may be different, but the principles should be the same - something pushes on the diaphram, causing fuel to flow through and out of the squirter. If the diaphram isn't being pushed, or it isn't returning, or the system is plugged, you won't get a squirt.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
Re: 318 stunble
[Re: 451Mopar]
#684177
04/30/10 06:56 AM
04/30/10 06:56 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
what kind of carb?
if it's an edelbrock/carter, you can change the position of the linkage to a hole closer to the body of the carb, that'll give a larger pump shot, if the accelerator pump is working correctly. you should see a solid squirt when snapping the throttle.
Re: 318 stunble
#684181
04/30/10 05:50 PM
04/30/10 05:50 PM
RapidRobert
might take off the squirter & see if the brass valve is loose and move the throttle and see if it squirts and if not then I think the carb needs to come off to get at the AP diaphram under the square cover. I'm assuming that the external linkage is intact/moving, that it's something inside
Re: 318 stunble
#684183
05/01/10 11:08 AM
05/01/10 11:08 AM
RapidRobert
What was in there a ball or the pointed needle. I'm not a holley guy and one I have has just the needle
Re: 318 stunble
[Re: RapidRobert]
#684184
05/01/10 10:40 PM
05/01/10 10:40 PM
Posts: 738 TN
'84 D150 Shorty
Pickup Man
Pickup Man
TN
it was a ball bearing type with a small weight above it. The bearing seals the opening, with the weight on top, in a bore located beneath the fuel nozzles
