318 stunble #684168
04/30/10 12:23 AM
04/30/10 12:23 AM
TN
'84 D150 Shorty Offline OP
Pickup Man
Pickup Man
TN
Just got the 318 running today, but got a small problem. At idle, it runs smooth with no miss, but if i move the throttle abrubtly, it stumbles or chokes briefly then catches up and revs up smoothly. if i move the throttle slowly it doesnt do this. what would cause that?
Re: 318 stunble [Re: '84 D150 Shorty] #684169
04/30/10 12:28 AM
04/30/10 12:28 AM
check for an immediate squirt of gas when you move the throttle & I'm assuming it's warmed up/choke off as inadequate choke closing can do it
Re: 318 stunble [Re: RapidRobert] #684170
04/30/10 12:39 AM
04/30/10 12:39 AM
TN
Pickup Man
Pickup Man
TN
k, i just checked that, and didnt see gas squirting in. a little bit of fuel is going, but i should be able to see a visible squirt of fuel goin in right? if so, what would cause that?
Re: 318 stunble [Re: '84 D150 Shorty] #684171
04/30/10 12:42 AM
04/30/10 12:42 AM
take the top off and check the acclerator plunger neoprene cup for rips/tears & if good check the float level (good idea anyway as it's easy and you have the top off)
Re: 318 stunble [Re: RapidRobert] #684172
04/30/10 12:43 AM
04/30/10 12:43 AM
TN
Pickup Man
Pickup Man
TN
okie doke. gonna do that now
Re: 318 stunble [Re: '84 D150 Shorty] #684173
04/30/10 12:45 AM
04/30/10 12:45 AM
I gotta hit the hay. I'll get w you tomorrow.
Re: 318 stunble [Re: RapidRobert] #684174
04/30/10 01:43 AM
04/30/10 01:43 AM
TN
Pickup Man
Pickup Man
TN
ok, checked the accelerator pump diaphram and adjusted the float level, same problem, but i noticed that if i held the choke partially closed, the stumble went away...any ideas?
Re: 318 stunble [Re: '84 D150 Shorty] #684175
04/30/10 02:42 AM
04/30/10 02:42 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I'm no carburetor expert, but here's my thoughts. With no visible fuel squirt when you hit the accelerator, that means your accelerator pump is not working properly. Running with the choke partially closed will give you more fuel, so the accelerator pump issue will not be noticeable - you're covering up the lack of an accelerator pump squirt by introducing more fuel into the system with the choke. So, we need to determine why your accelerator pump is not squirting.
On my Holley, when you hit the accelerator, the accelerator pump cam pushes on a lever, which then pushes on the accelerator pump diaphram, which forces fuel through a passage and out of the squirter. A spring inside the accelerator pump bowl forces the diaphram back when the accelerator goes back to idle position. If the lever is sticking, the diaphram will not return, and the accelerator pump cam can move all it wants but it won't be moving the lever (since it's stuck), and you won't get a squirt. The same thing would probably happen if the spring behind the diaphram was broken - it wouldn't return the diaphram, and you would get no squirt. You may also have a plugged passage to the squirter, or a plugged squirter, or even a wiped lobe on the accelerator pump cam.
The way your carb creates the squirt may be different, but the principles should be the same - something pushes on the diaphram, causing fuel to flow through and out of the squirter. If the diaphram isn't being pushed, or it isn't returning, or the system is plugged, you won't get a squirt.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: 318 stunble [Re: '84 D150 Shorty] #684176
04/30/10 04:08 AM
04/30/10 04:08 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
If it is an Edelbrock / Carter AFB/AVS type carb, check fuel bowl level as about to the level of the baffle inside the fuel bowl.
Re: 318 stunble [Re: 451Mopar] #684177
04/30/10 06:56 AM
04/30/10 06:56 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
what kind of carb?
if it's an edelbrock/carter, you can change the position of the linkage to a hole closer to the body of the carb, that'll give a larger pump shot, if the accelerator pump is working correctly. you should see a solid squirt when snapping the throttle.
2017 Grand Cherokee Overland
Re: 318 stunble [Re: patrick] #684178
04/30/10 09:52 AM
04/30/10 09:52 AM
TN
Pickup Man
Pickup Man
TN
The carb is a holley 2bbl, it is an older type (no oxygen feedback or other junk on it)
Re: 318 stunble [Re: patrick] #684179
04/30/10 09:56 AM
04/30/10 09:56 AM
what kind of carb?
idle it for a minute then pull the top off and as said the fuel level should be up to the slots in each float baffle in each side (eddy) then take off the AP plunger & plunge it into the well and see what you get for a squirt & if inadequate take off the squirter and see if the brass plunger w the pointed tip is in there & if so call your parts house and get another AP. If it's a leather one run a mini screwdriver around the inside perimeter between the leather and the spring to expand it a bit then slightly lube it & install. If a holley also see if the pointed needle is in place & if so take off the carb and the 4 bolts on the square AP metal cover and replace the pump diaphram
Re: 318 stunble [Re: patrick] #684180
04/30/10 09:56 AM
04/30/10 09:56 AM
TN
Pickup Man
Pickup Man
TN
when i depress the accelerator lever, it doesnt quite feel right. it feels lose. im thinking if i was moving the lever, i should feel it making a slight suction, but i dont, and i am definitely not seing a solid squirt of fuel.
Re: 318 stunble [Re: '84 D150 Shorty] #684181
04/30/10 05:50 PM
04/30/10 05:50 PM
might take off the squirter & see if the brass valve is loose and move the throttle and see if it squirts and if not then I think the carb needs to come off to get at the AP diaphram under the square cover. I'm assuming that the external linkage is intact/moving, that it's something inside
Re: 318 stunble [Re: '84 D150 Shorty] #684182
05/01/10 06:38 AM
05/01/10 06:38 AM
TN
Pickup Man
Pickup Man
TN
ok, i figured it out yall! thank you all for your help! it turned out that indeed the problem was in the accelerator pump, specifically, the check ball was stuck (probably from sitting too long). i bought a rebuild kit from autozone for 20 bucks, and overhauled the top half of the carb while it was on the motor. Easy as pie! the carb is a holley 2280 2bbl. chrysler used this carb for many applications for small blocks. the check ball was under the squirter nozzle assembly, and i found instructions in my chrysler dealer repair manual specific to this carb model for testing of the accelerator pump and float adjustments. maybe this will help someone else!! the engine accelerates crisp and smooth now!
Re: 318 stunble [Re: '84 D150 Shorty] #684183
05/01/10 11:08 AM
05/01/10 11:08 AM
What was in there a ball or the pointed needle. I'm not a holley guy and one I have has just the needle
Re: 318 stunble [Re: RapidRobert] #684184
05/01/10 10:40 PM
05/01/10 10:40 PM
TN
Pickup Man
Pickup Man
TN
it was a ball bearing type with a small weight above it. The bearing seals the opening, with the weight on top, in a bore located beneath the fuel nozzles
