timing for dummies #683769
04/29/10 06:03 PM
04/29/10 06:03 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
Can anyone give me a brief description on how do advance timing on a 69 383hp stock eng with an Eddie 750. I got a good idea on how to time the motor at idle but like to know how to time it at higher rpm…..
Re: timing for dummies [Re: ngpSatellite] #683770
04/29/10 06:23 PM
04/29/10 06:23 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
To the best of my knowledge, mechanical advance is established by your distributor advance plates. That, plus your initial timing, will establish your total timing.
Re: timing for dummies [Re: Pat_Whalen] #683771
04/29/10 06:28 PM
04/29/10 06:28 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
It depends on what kind of distributor you have to set mechanical/vacuum advance correctly.
Re: timing for dummies [Re: ngpSatellite] #683772
04/29/10 06:28 PM
04/29/10 06:28 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Give it all the initial timing it will take with out kicking back when starting it back up hot. If it bogs when starting it's to far advanced. Use a dial back timing light to find what the initial is when set. Bring RPMs up to 2800 or 3000 and see what your total is. If over 40 to 42 you will have to recurve the distributor
Re: timing for dummies [Re: sharpie] #683773
04/29/10 06:38 PM
04/29/10 06:38 PM
own private Idaho
N
N
own private Idaho
stock dist from autozone........ thx Doug!!
Re: timing for dummies [Re: ngpSatellite] #683774
04/29/10 06:41 PM
04/29/10 06:41 PM
Do you have a dialback? What is your initial now? I'd unplug/cap the vac adv hose and post what you have for initial then run the rpm up until it wont advance any more which may be over 3500 & see (& post) what you have. If you dont have a dialback make a magic marker mark on the harmonic dampener 2&1/4" to the right (clockwise) from the TDC line and this is 35.5 degrees which will give you a rough idea of where your total is at. Post how far (roughly) on either side of that mark you're at & we'll go from there. If you have a dialback you'll know exactly though mine is ~1 degree off compared to a good sears std one. EDIT .0632683" is 1 degree so if you have a 2-3" mike you can measure/mark on a strip of paper then transfer that to the dampener if you have no dialback for your total.
Re: timing for dummies [Re: ngpSatellite] #683775
04/29/10 07:13 PM
04/29/10 07:13 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
I hope this turns into a good informative post for both big block and small block and put in the archives if it isn't already there.
