Re: Car has Electrical Power but will not turn over
[Re: fury4speed]
#680838
04/26/10 05:04 PM
04/26/10 05:04 PM
RapidRobert
(1) need fire @ the "ign" terminal on the starter relay when you turn the key to start (ign2). (2) the "grn" terminal close to it on the same starter relay needs to be grounded when the trans is in park or neutral. need a jumper wire w alligator clips on each end to check (2) and a helper turning the key to "start" as you check for fire w a test light or VOM for (1).
[Re: RapidRobert]
#680839
04/26/10 06:11 PM
04/26/10 06:11 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Take a screw driver and arch between the terminals on the starter relay or on the starter solenoid and see what happens.Make sure that the neutral starter switch wire is hooked up.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: fury4speed]
#680841
04/26/10 06:38 PM
04/26/10 06:38 PM
MoparforLife
Upper Midwest
In that case make sure that the battery has a good charge and the connections at the battery posts are shiny clean. Remove the cables and scrape both the posts and the cables clean and make sure that they are good and tight
[Re: AARCONV]
#680844
04/26/10 07:39 PM
04/26/10 07:39 PM
fury4speed
corrosion/bad contact somewhere..does it crank when u jump the starter relay?
I will check that tomorow and also the NSS.
[Re: buildanother]
#680846
04/26/10 09:09 PM
04/26/10 09:09 PM
fury4speed
You don't have nss, I would check for 12 volts at the yellow wire on starter relay, when the key is turned to start.
That was my next Question , when did Chrysler Products start using them on Manual Trans Cars?
[Re: MoparforLife]
#680848
04/26/10 09:17 PM
04/26/10 09:17 PM
fury4speed
Go into the car and put your clutch in and the transmission in Reverse.
OK , why?
[Re: fury4speed]
#680849
04/26/10 11:09 PM
04/26/10 11:09 PM
MoparforLife
Upper Midwest
Some had a neutral clutch switch but memory escapes me which ones.
