Re: voltage fluctuations only at idle
[Re: Andrewh]
#679214
04/24/10 11:12 PM
04/24/10 11:12 PM
RapidRobert
Alt. I'd pull/check/clean the brushes. Easy/quick to do
[Re: Andrewh]
#679215
04/25/10 09:09 AM
04/25/10 09:09 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The voltage sense line you mention picks it's voltage from the battery, via the key switch. If that line is dirty then it'll sense lower voltage and up the alternator output.
Not sure how the electronic version of the older style regulator works, but the mechanical version is really just a switch turning the alternator on/off/on/off to maintain battery voltage. If the elctronic version does the same thing then it's operating normal. The mechinical style is adjustable as well, not sure if the electronic version is.
The newer style regulator (70 and up) varies the output of the alternator in a linear fashion, not the on/off/on/off method the old style uses. You can update to that style easily enough, NAPA sells the connectors for cheap.
[Re: Andrewh]
#679218
04/25/10 02:44 PM
04/25/10 02:44 PM
RapidRobert
Stumpy mentioned something I want to do, spraying the alt w something to clean it which sounds like it would clean the commutator bars/brushes as that is the make/brake connection point inside of it as long as you didn't wash the bearings/lube on each end
[Re: Supercuda]
#679219
04/25/10 06:38 PM
04/25/10 06:38 PM
Andrewh
I don't think this is how it works. If it did, I would think I would get the same pulses higher up in rpm just like the instrument vr. but not sure.
I might try spraying it first, but will still take apart the spare to see what is involved.
Well spare is the wrong word, since it can't be used. accidently broke the main stud off of it.
