voltage fluctuations only at idle #679211
04/24/10 06:58 PM
04/24/10 06:58 PM
Andrewh Offline OP
Andrewh  Offline OP
so I checked my voltages and need an opinion.
5.9 magnum. not sure which amp the alt is.
running the solid state 1 field voltage reg.
grounded the other field on the alternator.
battery voltage reads around 14.8 at idle.
Voltage reg sensing voltage reads around 14.5-14.7
The back of the alt jumps around 14.8 to 15.
Idle speed is about 800 rpm.
AT around 1k rpm the alt evens out and stops jumping around and sits at 14.5 with the same .2 drop from the battery to the vr.
Would you say it is the VR or just low rpm for the alt? no idea on the mileage on the alt. Jy replacement.
Re: voltage fluctuations only at idle [Re: Andrewh] #679212
04/24/10 07:25 PM
04/24/10 07:25 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
That sounds a bit high to me. But that little variation won't hurt anything.
Re: voltage fluctuations only at idle [Re: stumpy] #679213
04/24/10 08:52 PM
04/24/10 08:52 PM
Andrewh Offline OP
Andrewh  Offline OP
not hurt, annyoing. It causes the lights to pulse at idle.
Re: voltage fluctuations only at idle [Re: Andrewh] #679214
04/24/10 11:12 PM
04/24/10 11:12 PM
Alt. I'd pull/check/clean the brushes. Easy/quick to do
Re: voltage fluctuations only at idle [Re: Andrewh] #679215
04/25/10 09:09 AM
04/25/10 09:09 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The voltage sense line you mention picks it's voltage from the battery, via the key switch. If that line is dirty then it'll sense lower voltage and up the alternator output.
Not sure how the electronic version of the older style regulator works, but the mechanical version is really just a switch turning the alternator on/off/on/off to maintain battery voltage. If the elctronic version does the same thing then it's operating normal. The mechinical style is adjustable as well, not sure if the electronic version is.
The newer style regulator (70 and up) varies the output of the alternator in a linear fashion, not the on/off/on/off method the old style uses. You can update to that style easily enough, NAPA sells the connectors for cheap.
Don't be the exception.
Re: voltage fluctuations only at idle [Re: Andrewh] #679216
04/25/10 10:07 AM
04/25/10 10:07 AM
NH
72challorange Offline
He's Game
He's Game
NH
What's the voltage at the headlights? Should be pretty bright with that kind of voltage.
Tom
Re: voltage fluctuations only at idle [Re: 72challorange] #679217
04/25/10 10:17 AM
04/25/10 10:17 AM
Andrewh Offline OP
Andrewh  Offline OP
they are bright. Didn't measure, but I have them tapped off a relay, so it should be close to that 14.8.
I will see if I can figure out how to take the alt apart with a spare one to clean the brushes.
Re: voltage fluctuations only at idle [Re: Andrewh] #679218
04/25/10 02:44 PM
04/25/10 02:44 PM
Stumpy mentioned something I want to do, spraying the alt w something to clean it which sounds like it would clean the commutator bars/brushes as that is the make/brake connection point inside of it as long as you didn't wash the bearings/lube on each end
Re: voltage fluctuations only at idle [Re: Supercuda] #679219
04/25/10 06:38 PM
04/25/10 06:38 PM
Andrewh Offline OP
Andrewh  Offline OP
I don't think this is how it works. If it did, I would think I would get the same pulses higher up in rpm just like the instrument vr. but not sure.
I might try spraying it first, but will still take apart the spare to see what is involved.
Well spare is the wrong word, since it can't be used. accidently broke the main stud off of it.
