4 link question #678916
04/24/10 03:11 PM
04/24/10 03:11 PM
Peru
cbarracuda Offline OP
Peru
We rent the track today to try our new car. The track was not prepared, very poor traction. At first the wheels where spining and the car cearly headed towards the right, but then it went straight. It has a competition 4 link kit. Any advace please
Thank you
Re: 4 link question [Re: cbarracuda] #678917
04/24/10 03:40 PM
04/24/10 03:40 PM
Peru
Peru
LOOKS LIKE NEEDS PRE LOAD IN THE PASSENG SIDE .how do you adjust for a crapy track
Re: 4 link question [Re: cbarracuda] #678918
04/24/10 03:51 PM
04/24/10 03:51 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Good starting point is neutral preload and scale the car,you want 30 to 50pounds heaverier on the right rear tire.If your not turn the right upper bar one flat(nut adjuster) at a time for preload till you get the weight there.From there it's adjust as needed for handling and track conditions. I wouldn't make a bunch of adjustment based on one bad pass.If the car repeatedly drives right in either lane on multipal passes then add a little preload in the upper right bar as needed.
Re: 4 link question [Re: B G Racing] #678919
04/24/10 05:56 PM
04/24/10 05:56 PM
Peru
Peru
Thanks for the info I will borrow the scales and then put the driver inside and go for the 30 to 50 heavier on the right
Re: 4 link question [Re: cbarracuda] #678920
04/24/10 06:29 PM
04/24/10 06:29 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
you tune for track conditions with fornt and rear shocks and front travel
....BAD A$$ STREET CAR.....
Re: 4 link question [Re: n20mstr] #678921
04/24/10 06:30 PM
04/24/10 06:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats what I was thinking
Re: 4 link question [Re: Quicktree] #678922
04/24/10 08:56 PM
04/24/10 08:56 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We tune with shocks for weight transfer,hook and hit.Driving right or left we use preload.
Re: 4 link question [Re: B G Racing] #678923
04/24/10 08:58 PM
04/24/10 08:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: 4 link question [Re: MR_P_BODY] #678924
04/24/10 10:07 PM
04/24/10 10:07 PM
Peru
Peru
Which of the holes will provide the best traction in a track with poor traction?
I've set mine where the two x's are
Re: 4 link question [Re: cbarracuda] #678925
04/24/10 10:12 PM
04/24/10 10:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... your asking something that cant be answered
with 2 Xs.... whats the IC length and height... weight
of the car and HP... where's the CG
Re: 4 link question [Re: MR_P_BODY] #678926
04/24/10 10:22 PM
04/24/10 10:22 PM
Peru
Peru
Car weights 2700 lbs. with driver, HP around 700, wheel base 117". I can't answer the other two questions. The car is sitting low
Re: 4 link question [Re: cbarracuda] #678927
04/24/10 10:29 PM
04/24/10 10:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Plot out the holes and start about 45" out and 6" up
... you may need to move outward to about 55"... each
car is some what trial and error but thats a starting
point
Re: 4 link question [Re: MR_P_BODY] #678928
04/24/10 11:33 PM
04/24/10 11:33 PM
Peru
Peru
point
It was already at 45 but it was low about 2 inches, so I'm going to try to move outwards at 55 and go 6 or 7 inches up
thank you
Re: 4 link question [Re: MR_P_BODY] #678929
04/26/10 05:06 PM
04/26/10 05:06 PM
Peru
Peru
What do you think of this weight distribution:
56 front, 44 rear is it ok?
or is it better to add weight to get 50 50?
Re: 4 link question [Re: cbarracuda] #678930
04/26/10 05:09 PM
04/26/10 05:09 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Most scale heavy on the front,you should be fine.
Re: 4 link question [Re: B G Racing] #678931
04/26/10 09:06 PM
04/26/10 09:06 PM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
Are you sure you have 117" wheel base? If that is a stock wheelbase barracuda, I would bet it's not. I usually go 1/2 wheelbase about 3 inches high to start.
Re: 4 link question [Re: SCDaytona] #678932
04/26/10 09:31 PM
04/26/10 09:31 PM
Peru
Peru
No, It's not for my Barracuda. I'm working on a 1953 Studebaker with 512 Mopar 727- 8 3/4
