fixing cast iron heads? #675697
04/20/10 01:57 PM
04/20/10 01:57 PM
Stratford,Ct
7sec.cuda Offline OP
Stratford,Ct
does anybody fix cracks in cast iron heads? i have a set of older stage 4 heads that one of them cracked in between the seats and was wondering if it worth the effort or money to fix it thanks
Re: fixing cast iron heads? [Re: 7sec.cuda] #675698
04/20/10 02:02 PM
04/20/10 02:02 PM
Do a cast iron welding search for your area or deisel engine repairs. Cast iron welding is done nation wide, especially on heavy(comercial) deisel engines. You'll have to decide on the costs if it's worth it or not. Aluminum heads are a lot better choice now
Re: fixing cast iron heads? [Re: Cab_Burge] #675699
04/20/10 07:20 PM
04/20/10 07:20 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Jeff at Modern has fixed mine in the past!
Re: fixing cast iron heads? [Re: 7sec.cuda] #675700
04/20/10 08:22 PM
04/20/10 08:22 PM
Massachusetts, USA
maxeffort Offline
maxeffort  Offline
Massachusetts, USA
Yes, I can help you with expert cast iron stitch repair. I'm right in MA if you need help with those.
official member of the Sleepy Labeef band alumni club.
Re: fixing cast iron heads? [Re: maxeffort] #675701
04/20/10 11:35 PM
04/20/10 11:35 PM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
Indy cylinder head fixed one of my max wedge stocker heads. It had a sand casting pit open up after racing it for a while. They weren't the cheapest or the easiest to deal with, but I am about to start my 3rd season since the repair on that engine. In the end, that is what matters.
Jeff Day
Precision Automotive Machine
Canton, Ohio
Re: fixing cast iron heads? [Re: 7sec.cuda] #675702
04/21/10 08:07 AM
04/21/10 08:07 AM
Massachusetts, USA
maxeffort Offline
maxeffort  Offline
Massachusetts, USA
I posted some photos of simple and complicated repairs. Stitch technique works vey well for cracks between the seats. When you weld, you put the head casting through a lot of changes and it needs a complete rebuild and machining.
Usually the cracks can just be stitched cold, the valve job touched up and your good to go. It's very common repair for us on the magnum heads, they crack between the seats all the time. After stitching the heads are pressure tested and the resulting repair has been very reliable.
Re: fixing cast iron heads? [Re: maxeffort] #675703
04/21/10 11:22 AM
04/21/10 11:22 AM
Stratford,Ct
Stratford,Ct
thanks i will give you a call
