Re: Small block intake question
[Re: mopacltd]
#675652
04/20/10 03:52 PM
04/20/10 03:52 PM
Posts: 5,894 Florida
Locomotion
This is the only small block intake test that I know is available on the net. There are other intakes not tested that would work also. (i.e.: M-1 single plane, Stealth, Offy Port-O-Sonic, etc.) Considering the light weight and rpm's, a single plane may work well despite the little 318. But some of the bigger dual planes may not disappoint either. But I always figure that it's safer to lean on the conservative side. Gearing, converter and cam duration will have an affect on the options. I assume you'll be using 340/360 heads for the port size? 7,500? Mopar Muscle Magazine small block intake test.
[Re: mopacltd]
#675653
04/20/10 05:06 PM
04/20/10 05:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Some will also make a difference at what RPM you plan on launching at... if its a low RPM a big single plane might hurt... JMO
[Re: mopacltd]
#675655
04/20/10 07:46 PM
04/20/10 07:46 PM
Posts: 127 Phoenix, Arizona
HerboldRacing
Phoenix, Arizona
I am looking for a comparison/test results on small block mopar single plane intakes. Building a 318(or close to) for my front engine dragster. Installing a 750 dominator and need help deciding on the intake. Will only be turning 7500 or less RPM. Anyone know of articles or comparison charts that I could look up?
I didn't know they made dominators that small, Chucko!
Maybe you can find an old holley strip dominator intake somewhere? I've got one on my 340. Something like this:
http://www.racingjunk.com/category/98/In...NTAKE-RARE.html
[Re: mopacltd]
#675659
04/20/10 09:40 PM
04/20/10 09:40 PM
Posts: 52 Bakersfield, CA
MarkKirby
Bakersfield, CA
Hey Chucko!!!
I've got a Port O Sonic that I just took off my 416 stroker. Thought I would bolt on a Super Victor to pickup a little but gained absolutely nothing. Port O Sonic was probably one of the best if not THE best small block manifold ever.
Bout to put it on Racing Junk if anyone's interested.
Mark & Nancy Kirby
1971 Plymouth Duster
The Grape Ape
10.20 @129mph 1.32 60'
[Re: MarkKirby]
#675661
04/20/10 11:28 PM
04/20/10 11:28 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Hey Chucko!!!
I would buy Mark's Port-o-sonic if I were doing this deal. Hey Mark-on a personal note, I see you at Bako at all of the WCHRA races. Your driving and your car are very impressive. For all of you Moparters who don't know this guy is around at the end of every race I attend. Good job!
