carb choice #674096
04/18/10 09:45 PM
04/18/10 09:45 PM
Madison, Wisconsin
E
EASY Offline OP
EASY  Offline OP
E
Madison, Wisconsin
anyone use a quick fuel carb on a mild 383?
Looking at a 750 duel pumper mech secondaries.
Re: carb choice [Re: EASY] #674097
04/19/10 01:20 AM
04/19/10 01:20 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Define "mild". For a street car with a hydraulic flat tappet cam and moderate gearing, You may be happier with a Vacuum Secondary 750.
Re: carb choice [Re: StealthWedge67] #674098
04/19/10 01:25 AM
04/19/10 01:25 AM
"mild 383" that'd be my suggestion
Re: carb choice [Re: RapidRobert] #674099
04/19/10 04:46 AM
04/19/10 04:46 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
With a bit of work my 625cfm AVS pushes my (very) mild 383 3600lb Barracuda to 5750rpm in top gear. A 750 may have me at the top end but I bet I get away faster with the 625. I was hell bent getting a 750 on my engine some time ago but after much A/F logging & tuning I went back to the 625 for better driveability. When I upgrade the engine I will upgrade the carb as well but a 625 AVS with a few mods is all it needs for now.
Re: carb choice [Re: EASY] #674100
04/19/10 06:29 AM
04/19/10 06:29 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Easy,
I run a QF SS-750-AN (DP)on my mild 340. It has annular boosters which QF says it's actual cfm is 735. It has adjustable secondary mechanical linkage which you can delay either 40% or 60% with just a linkage swap to help tune the secondaries. The annular boosters gives better throttle response versus my other two DP carbs with downleg boosters. Call the guys at QF and ask them for their suggestions.
You might want to add some more info about your combo unless your already sutup for a DP.
Re: carb choice [Re: YO7_A66] #674101
04/19/10 07:19 AM
04/19/10 07:19 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Easy,
Annular boosters can make a carb that is a bit big work well down low without the restriction of a small carb at the top end.
Converting my AVS to annular boosters & a few other minor mods gave me .3 sec & the same economy with 3.91 gears that I used to get with 3.23's
Re: carb choice [Re: RapidRobert] #674102
04/19/10 08:55 AM
04/19/10 08:55 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Unless it is a 4 speed?
Re: carb choice [Re: StealthWedge67] #674103
04/19/10 03:21 PM
04/19/10 03:21 PM
Madison, Wisconsin
E
EASY Offline OP
EASY  Offline OP
E
Madison, Wisconsin
duelplane intake flat tappet cam from comp cams. Stock exhaust.
I will probably go to headers and rollercam in the near future.
Re: carb choice [Re: EASY] #674104
04/19/10 05:33 PM
04/19/10 05:33 PM
NC
Badfish67 Offline
Badfish67  Offline
NC
For the price your going to pay for a Quick Fuel you can call Patrick at Pro Systems and have him build you a carb that is custom made for your combination.
1967 Barracuda 360ci/727 9.723ET @139.44mph
