Anyone have problems with repro belts? #670432
04/15/10 01:10 PM
04/15/10 01:10 PM
Minneapolis, MN
hemi70se Offline OP
hemi70se  Offline OP
Minneapolis, MN
Has anyone else had problems with repro engine belts? I just threw off my Alt belt after a high RPM joy ride. I KNOW I had it tight because I HAD to get it VERY tight to stop it from squealing. This is the 2nd car I've had where this happened with a new repro belt. I'm assuming these must like to stretch and need to be checked daily.
Re: Anyone have problems with repro belts? [Re: hemi70se] #670433
04/15/10 01:42 PM
04/15/10 01:42 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Dirk,
Me too! Three different repro (Quanta) belts, two different engines. Similar problem.
Ola
Re: Anyone have problems with repro belts? [Re: hemi70se] #670434
04/15/10 02:31 PM
04/15/10 02:31 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Yep:
They are terrible. Especially bad on stroker engines that have a lot of grunt.
But they work great for getting on and off the trailer.
MB
Re: Anyone have problems with repro belts? [Re: HPMike] #670435
04/15/10 02:46 PM
04/15/10 02:46 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I went through three of them on my '70 383 4-spd RR. Always stretched and would toss them during high RPM upshifts However, the old Gates belt (from the previous owner circa '82) would always hold up just fine
Re: Anyone have problems with repro belts? [Re: 70440+6bbl] #670436
04/15/10 03:12 PM
04/15/10 03:12 PM
Minneapolis, MN
hemi70se Offline OP
hemi70se  Offline OP
Minneapolis, MN
I'm so lucky I made it just a short blast around my neighborhood. I opened my hood when I got back to find the belt had thrown off and it was starting to gurgle from getting too hot. I could have cooked my motor if I had really been going some where! I am done with the repro Quanta belts. That stupid part # molded in is not worth cooking your motor!
Re: Anyone have problems with repro belts? [Re: hemi70se] #670437
04/15/10 04:22 PM
04/15/10 04:22 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I stick to gates belts. Mine's not an OE restoration. I actual drive mine and have fun with it.
Re: Anyone have problems with repro belts? [Re: 70440+6bbl] #670438
04/15/10 06:51 PM
04/15/10 06:51 PM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Gates is the only way to go.
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Anyone have problems with repro belts? [Re: hemi70se] #670439
04/15/10 10:01 PM
04/15/10 10:01 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
that's what i did on my resto, i used gates belts. i'm not going for points.
Re: Anyone have problems with repro belts? [Re: joelson6] #670440
04/15/10 10:37 PM
04/15/10 10:37 PM
New State
kidmopar Offline
kidmopar  Offline
New State
I actually bought my belts (1970 Challenger 440 Alternator/ Power steer belt) from good 'ol Mother Mopar! They are STILL available & say MOPAR on them. Just not "incused" like the old syle belts. My
Re: Anyone have problems with repro belts? [Re: hemi70se] #670441
04/16/10 07:59 AM
04/16/10 07:59 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I looked into carring these belts. So I bought a set for my own car.As a test trial. I had nothing but squeeking , squeeling and they wouldn't stay tight.
I have one customer whom in order to get his to stop squeeling he burnt an alternator bearing up it was so tight.
I use the Mopar brand belts (supplied by goodyear btw) and not worry about 'someone elses approval - or points'
If someone needs the info, I have an old Mopar brand belt/hose guide to look them up if needed
Re: Anyone have problems with repro belts? [Re: gtx6970] #670442
04/16/10 01:27 PM
04/16/10 01:27 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Yep, Bill you nailed it. I did the same thing. They at least say Mopar even though they're not "correct".
If memory serves me correctly, most of the OE belts were 11/32" in width. I had a hard time at the local parts store finding one a decent length that would work, so I got a 10/32" and used it on one of my cars. It was a closer length to the original and fit in the groves better. I think it might have been a smog pump belt or something. Anyway, several high rpm runs later and it hasn't been thrown. Just a thought for you guys like me that love WOT !
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Anyone have problems with repro belts? [Re: Dixie] #670443
04/17/10 01:54 PM
04/17/10 01:54 PM
Minneapolis, MN
hemi70se Offline OP
hemi70se  Offline OP
Minneapolis, MN
I picked up a new Gates belt, but I don't like the "cogged" teeth on it. Does any other company make one w/o the teeth? Mopar brand maybe?
Re: Anyone have problems with repro belts? [Re: hemi70se] #670444
04/17/10 02:28 PM
04/17/10 02:28 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Those repop belts are like a rubber band... ...Is there any quick reference in the mopar belt's number system to identify the available sizes ????
Re: Anyone have problems with repro belts? [Re: hemi70se] #670445
04/18/10 09:47 PM
04/18/10 09:47 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
i think i got dayco belts, i said in an earlier post that it was gates but i was wrong. i'll have to check to be sure. that was one of my requirements, no "cogged" teeth.
Re: Anyone have problems with repro belts? [Re: joelson6] #670446
04/18/10 10:33 PM
04/18/10 10:33 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I also burnt up an alternator making the repro belt to tight. I ended up getting a different back on my original alternator when it was redone and lost my numbers. A repro belt is not even that good for pulling on and off the trailer. You can't even rev it a little bit sitting still. I have had no problem with the Mopar belts. They may now be getting harder to find from your dealer?
