Who has Experience with Phoenix Slicks #669970
04/14/10 10:46 PM
04/14/10 10:46 PM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
Anyone here have any experience with the Phoenix 10.5 slicks? Just looking for opinions. How many passes are you getting out of them? Do the side walls stay in them or do they give up the ghost in 30 passes?
We are needing to replace our Hoosiers and since they only last about 30-40 passes before the side walls give up we're now looking at Phoenix.
Kevin
Re: Who has Experience with Phoenix Slicks [Re: KD800X] #669971
04/14/10 11:13 PM
04/14/10 11:13 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I don't run them anymore but had good luck with them when I did, I got more life out of them than the Hoosiers, or MT of the same size. I swithed to MT for one reason, I needed a size they have 31-10.5 W, I used to run the Phoenix 29.5- 11.5 W's but can't run those in some of my races, so I just decided swaping tires wasn't worth it and stick with the 10-5 MT now. Guess a lot depends on what you are running, car, weight, how fast, size ect, but I really like the Phoenix slicks, ran them pretty much for 7 or 8 years. My car runs low 10's, weighs 3700 with me, 60's were consistent 1.41 oe so, depending on which track at density altitude. EDIT BELOW
Didn't notice until after I posted that you asked about Phoenix 10.5, thought it was Phoenix in general, my info may not help you, but the 31-10.5 MT's have been better for me than the Hoosiers.
Re: Who has Experience with Phoenix Slicks [Re: wyoming] #669972
04/14/10 11:38 PM
04/14/10 11:38 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
we also run the 29.5 11.5 w tire and have great luck in a 900hp 3800 lb car! Much better then the hoosier as far a longevity...
Re: Who has Experience with Phoenix Slicks [Re: joshking440] #669973
04/15/10 07:32 AM
04/15/10 07:32 AM
KEV,you know what i like.
i have heard only but good things about phoenix.
Re: Who has Experience with Phoenix Slicks #669974
04/15/10 07:43 AM
04/15/10 07:43 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
look at whats on the back of damn near every fast 10.5" tire car in the country........... M/T's
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Who has Experience with Phoenix Slicks [Re: StripeHOG] #669975
04/15/10 09:58 AM
04/15/10 09:58 AM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
They hook on the cords!! LOL I use them and like them
Diego
Re: Who has Experience with Phoenix Slicks [Re: Diego_Ted] #669976
04/15/10 10:08 AM
04/15/10 10:08 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
We have tried them all... It's Phoenix only for us guys around here now.
Re: Who has Experience with Phoenix Slicks [Re: 727builder] #669977
04/15/10 02:33 PM
04/15/10 02:33 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I used pheonix 29.5x11.5x15w they hooked like nothing else but they are quite heavy.
Re: Who has Experience with Phoenix Slicks [Re: sshemi] #669978
04/15/10 02:50 PM
04/15/10 02:50 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We run the Phoenix 31-13-15's F9 compound on the duster. We tried some hoosiers once and did not like them. Phoenix has never let us down! We get on average 300 runs on a set.
Re: Who has Experience with Phoenix Slicks [Re: cl440] #669979
04/15/10 08:03 PM
04/15/10 08:03 PM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
Hey guys, thanks for your input! You've been a big help!
It sounds like Phoenix is a good direction to go. I know M/T's are good also but I think Peoenix are going to be the choice.
I see they are now offer a 31-10.5W. But, I don't know if we can fit it under the car.
Besides I don't know how 4 1/2 inches more of roll out will effect the converter which is set up for 30" tires. So we probably will stay with the 29.5-10.5's.
Thanks again
Kevin
Re: Who has Experience with Phoenix Slicks [Re: cl440] #669980
04/16/10 08:38 AM
04/16/10 08:38 AM
NC
440Jim Offline
440Jim  Offline
NC
Now that is good mileage! I thought I was doing well with 200+ on my Phoenix 12.2 x 31.25 W
For the original poster. Try running inner tubes and as much air pressure as you can hook. This helps tire (sidewall) life. Also a nice wide rim. I have heard many racers successfully running 33 x 10.5 W tires on 14" wide rims.
10-5-29-5-15
10-5-31-0-15w
10-5-33-0-15w
12-2-31-25-15w
Phone Coker Tire and ask them to check a few pairs for rollout. The 31x10.5W is rated 99.5", but they might have a set around 97 on the rack.
Re: Who has Experience with Phoenix Slicks [Re: 440Jim] #669981
04/16/10 08:43 AM
04/16/10 08:43 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I really like the Phoenix used to use the 28 X 10.5 now the 362 29.5 X 11.5 they hook till the cords show so watch them! LOL!!
Re: Who has Experience with Phoenix Slicks [Re: Dodgem] #669982
04/16/10 12:50 PM
04/16/10 12:50 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I didn't know Phoenix was now building a 31-10.5W slick, that tire may be worth checking out, just bought a new set of MT's so it'll be a bit before I need new ones, I may want to give the new Phoenix 10.5W a try, I sure liked all their other slicks.
Re: Who has Experience with Phoenix Slicks [Re: Dodgem] #669983
04/16/10 08:03 PM
04/16/10 08:03 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
same size as I run, and it's true about the cord's.
Re: Who has Experience with Phoenix Slicks [Re: 440Jim] #669984
04/16/10 09:18 PM
04/16/10 09:18 PM
NW Pa.
KD800X Offline OP
KD800X  Offline OP
NW Pa.
10-5-29-5-15
10-5-31-0-15w
10-5-33-0-15w
12-2-31-25-15w
I would love to run 33" tall tires but we can't get them in the wheel openings. We're running a 65 Coronet with stock wheel openings and mini tubs. We run some NSS races so we want to stay with 10.5" tall tires. The car weights 3700 lbs and runs 9.70's - 9.80's, and the side walls do take a beating, so tubes are a good thought.
Any one else running tubes?
Thanks again.
Kevin
Re: Who has Experience with Phoenix Slicks [Re: KD800X] #669985
04/17/10 05:49 AM
04/17/10 05:49 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We use Phoenix and also use tubes.The tubes will keep the sidewalls from going away.We are getting MANY runs on Phoenix and they will hook to the cords as mentioned.
Nautilus Racing-
