No electrical anywhere. #669639
04/14/10 02:40 PM
04/14/10 02:40 PM
duals Offline OP
duals  Offline OP
I have a 1974 Scamp with a 318, backed it out of garage yesterday and it started fine and ran, has new battery, went to put it back in and there was nothing, no electrical to any thing, no lights in or out, nothing. Any ideas to what might cause this, getting pi$$ed.
Re: No electrical anywhere. [Re: duals] #669640
04/14/10 02:42 PM
04/14/10 02:42 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
New battery before or after you backed the car out?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: No electrical anywhere. [Re: HealthServices] #669641
04/14/10 02:50 PM
04/14/10 02:50 PM
okla.
O
okie Offline
okie  Offline
O
okla.
Check your fusable link to see if it is good. They will go bad like that and everything goes dead. Good Luck! Ronnie
Re: No electrical anywhere. [Re: okie] #669642
04/14/10 03:10 PM
04/14/10 03:10 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Engine and forward light harness fusible link
When you check the fusible link, make sure you feel the entire length of the wire for bulges. When the fusible link blows, it doesn't always look like it is bad from the outside. I would remove it and check it with an ohm meter for continuity. If it is bad you will be able to stretch it if you pull on both ends.
Re: No electrical anywhere. [Re: HealthServices] #669643
04/14/10 03:18 PM
04/14/10 03:18 PM
duals Offline OP
duals  Offline OP
New battery today
Re: No electrical anywhere. [Re: duals] #669644
04/14/10 03:35 PM
04/14/10 03:35 PM
So Cal
So Cal
New battery today
This may sound stupid but a lot of people do do it. Did you remove the plastic caps off of the battery post before you put on the the battery clamps?
Otherwise I would check for voltage at the starter relay, if it is there check the fusable link like the others mention.
Re: No electrical anywhere. [Re: HealthServices] #669645
04/14/10 03:37 PM
04/14/10 03:37 PM
duals Offline OP
duals  Offline OP
OH you mean those pretty looking caps, DAMN !!! I did take those off , now looking for the fuseable link ?
Re: No electrical anywhere. [Re: duals] #669646
04/14/10 03:39 PM
04/14/10 03:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It will be going from the starter relay to the bulkhead connector. Get your test light out and start at the battery and trace from there.
Re: No electrical anywhere. [Re: stumpy] #669647
04/14/10 03:41 PM
04/14/10 03:41 PM
duals Offline OP
duals  Offline OP
Thanks a bunch !!
Re: No electrical anywhere. [Re: duals] #669648
04/14/10 03:48 PM
04/14/10 03:48 PM
So Cal
So Cal
If you have voltage at the big red wire at the starter relay, check the thicker wire from the (blue in this picture) leading from the relay to the bulkhead connector. disregard the arrows
Re: No electrical anywhere. [Re: HealthServices] #669649
04/14/10 04:08 PM
04/14/10 04:08 PM
jump from the large batt stud on the starter relay on the bottom in the pic into the center of the bulkhead on top where the fusible link goes in, w a metal probe to bypass it & if you're good NAPA has Mopar fusible links (16 ga I think)
Re: No electrical anywhere. [Re: RapidRobert] #669650
04/14/10 04:40 PM
04/14/10 04:40 PM
duals Offline OP
duals  Offline OP
Thanks for all of the help, I am the Mopar dumba$$ of the day played around with the wires including the battery ground with the lights turned on no lights move groung around lights, hit ignition switch no lights, damn looks like I need some ground cable repair, going to hide for awhile
Re: No electrical anywhere. [Re: duals] #669651
04/14/10 06:07 PM
04/14/10 06:07 PM
So Cal
So Cal
Maybe not a bad ground but I think most of us have been in similar situations where we scratch our heads then find something simple was wrong.
