Re: No electrical anywhere.
[Re: duals]
#669640
04/14/10 02:42 PM
04/14/10 02:42 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
New battery before or after you backed the car out?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#669643
04/14/10 03:18 PM
04/14/10 03:18 PM
duals
[Re: stumpy]
#669647
04/14/10 03:41 PM
04/14/10 03:41 PM
duals
[Re: duals]
#669648
04/14/10 03:48 PM
04/14/10 03:48 PM
Posts: 7,759 So Cal
HealthServices
So Cal
If you have voltage at the big red wire at the starter relay, check the thicker wire from the (blue in this picture) leading from the relay to the bulkhead connector. disregard the arrows
Allen
#669649
04/14/10 04:08 PM
04/14/10 04:08 PM
RapidRobert
jump from the large batt stud on the starter relay on the bottom in the pic into the center of the bulkhead on top where the fusible link goes in, w a metal probe to bypass it & if you're good NAPA has Mopar fusible links (16 ga I think)
