Page 1 of 7 1 2 3 4 5 6 7
I give up, 440's just run HOT #66094
05/30/08 11:24 AM
05/30/08 11:24 AM
toronto canada
69chargeryeehaa Offline OP
toronto canada
ok, here's the deal, 69 charger r/t, 440/727/8.75 with 3.23. Stock 440 with eddy CH4B intake, eddy 1411 750 afb. New stock rad, shroud, stock fan, 180*deg stat, electric fan on front (pusher), insulating carb gasket/spacer. That's what I'm working with.
It seems like whenever it gets warmer, the car just starts to run hot only when sitting at a light, drive thru, ect....
Timing is perfect, 15*deg initial, 35 total, 14 vac. Plugs look perfect, the car runs perfect. Driving temp is always 185*deg, but when you sit at a light, it creeps up to 190, sitting in a drive thru last night and it went to 200 and then started running like crap. I just don't get why this thing runs hot, my old charger, identical setup (intake, timing, carb, ect...) did the EXACT same thing. Coolant is clean, recently changed, hoses are not collapsing, thermostat confirmed on the stove, engine has perfect compression, no oil use, <10000mi on rebuild, no crud in the motor/rad it's all NEW.
Someone please tell me a solution, this is driving me nuts I've tried everything to solve this nothing works. The electric fan just prolongs the temp creep up, but it still gets to 195+ and then starts running like crap. I've changed the:coil, ecu (chrome), plugs, wires, dist pickup, ect....EXACT SAME THING. It's not a ignition issues, it seems to be a carb issue when it runs bad when getting hot, but if it didn't run hot it would run perfect..IDEAS????? or is this just the way it is????
Re: I give up, 440's just run HOT [Re: 69chargeryeehaa] #66095
05/30/08 11:33 AM
05/30/08 11:33 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've got a similar combo and had a similar problem. Got rid of the pusher and the clutch fan and now run an 18" fixed steel flex-a-lite. Never seen 190 since I put it on. 4.30 gears, 70mph on the highway. No problem.
Re: I give up, 440's just run HOT [Re: 69chargeryeehaa] #66096
05/30/08 11:37 AM
05/30/08 11:37 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
That extra fan is blocking more than it is helping.
Re: I give up, 440's just run HOT [Re: 69chargeryeehaa] #66097
05/30/08 11:39 AM
05/30/08 11:39 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Here's one quick and easy thing to try. Set your initial timing to 20 degrees and see what happens. This may cure your problem. If it does, just work your dist. to adjust total timing.
Re: I give up, 440's just run HOT [Re: GODSCOUNTRY340] #66098
05/30/08 11:56 AM
05/30/08 11:56 AM
Has the 440 been taken down and completely cleaned out? (hot tanked)
I know you said you put in a new radiator etc. but here is a problem I used to have:
Every '71 model vehicle that our family has owned would overheat. We'd boil out the radiator and that would help for about 6-8 months and then it would start doing it again.
What I finally figured out was that casting sand from the factory was in the water passages of the engine block and would eventually make it's way into the radiator and partially plug it.
It was maddening until I finally took a 318 completely down to the block and found all kinds of crap in it.
I know you said stock fan but is it fixed or a clutch type?
I've always run the clutch type and never had a problem.
Re: I give up, 440's just run HOT [Re: MoparforLife] #66099
05/30/08 11:58 AM
05/30/08 11:58 AM
toronto canada
toronto canada
it was doing the same thing before the electric fan.
Re: I give up, 440's just run HOT [Re: bobby66] #66100
05/30/08 11:59 AM
05/30/08 11:59 AM
toronto canada
toronto canada
my issue is at idle, not at speed?
Re: I give up, 440's just run HOT [Re: GODSCOUNTRY340] #66101
05/30/08 12:00 PM
05/30/08 12:00 PM
toronto canada
toronto canada
well, i really don't feel like re-curving the dist, at 15 initial it's close enough is'nt it? I was actually thinking about the opposite, running it at factory 5 deg initial??? would that make it run hotter???
Re: I give up, 440's just run HOT #66102
05/30/08 12:03 PM
05/30/08 12:03 PM
toronto canada
toronto canada
the fan is fixed. I'm 1000% sure it's NOT anything in the engine, it was tanked, ect... the problem is NOT intermittent, it's exactly the same, when ever the outside temps rise, it starts to run hot only at idle...
Re: I give up, 440's just run HOT [Re: 69chargeryeehaa] #66103
05/30/08 12:05 PM
05/30/08 12:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what dist is it ?
whats the bore size currently at ?
what fan setup and are the parts new or 40 years old ?
what tuning have you done to that carb ?
Re: I give up, 440's just run HOT [Re: MoparforLife] #66104
05/30/08 12:05 PM
05/30/08 12:05 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I agree about getting rid of the pusher fan.
200 will not hurt a thing. It sounds like you havea fuel line to close to the exhaust and when you are sitting still it is not getting enough fresh air blow through that area to keep it cool. This can also make it run lean and that can make it run hoter.
Also what percentage of antifreez to water are you running? Too much anti freeze reduces cooling ability. What Idle RPM? Where does the carb get air? Are you useing stock ratio pullys?I have a 4cyl 2.2 K-car fan on my cuda and hardly ever do I have to turn it on even at *90F. Only when I idle at the line at the bank for a long time, then is the only time I turn the fan on and the little 2 blade low rom fan cools it right down to 195 in nothing flat. I have a 195 T-stat. I used a laser temp gauge to find the hottest part of the radiator and put the fan directly over that area since the shroud only covers part of the radiator.
Re: I give up, 440's just run HOT [Re: HotRodDave] #66105
05/30/08 12:20 PM
05/30/08 12:20 PM
MD
p d'ro Offline
p d'ro  Offline
MD
So you are using this 2.2 fan as a pusher. I also have a 440 in my 67 R/T that, at idle, gets up to 210. i know that is not a danger zone yet, but I have not let it sit for longer and fear w/ summer coming that it will continue to rise. I was told to get an elec. fan as a pusher, my current fan is fixed, 180 tstat, clean recored 4 core orig. radiator, etc. Will the pusher electric help??
My car still runs well at these temps. I fear this Charger has a fuel line, maybe metal, running too close to the block. I would move it or insulate it as my '68 Firebird had this issue and would eventually die until I let it cool for 1/2 hour...
retarding the timing increases heat. I will advance a little more and see what happens and check that the fuel is not lean/// Any other suggestions for both of us. Sorry to partially hijack...
Re: I give up, 440's just run HOT [Re: 69chargeryeehaa] #66106
05/30/08 12:23 PM
05/30/08 12:23 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Here is your easiest solution.
Bring it down here, have a friend follow you.
Leave title, keys, etc.
Then have your friend drive you back home
Problem Solved
Re: I give up, 440's just run HOT [Re: bobby66] #66107
05/30/08 12:25 PM
05/30/08 12:25 PM
toronto canada
toronto canada
you would'nt be able to reccommend a flexalite fan that would fit???? i'm really thinking it's a air flow issue at idle, i'd like to remove the electric fan and put a better fan on the car....
currently i have the fixed stock 7-blade fan and stock shroud.
Re: I give up, 440's just run HOT [Re: HotRodDave] #66108
05/30/08 12:27 PM
05/30/08 12:27 PM
P
Paul_Fancsali Offline
P
I 'm going back to a 195 stat to get my car to 200 degrees the running part as stated is from a fuel problem or that edel carb. Recently it has been cool in Pa and I have trouble getting to 180 even with 4.30s Your problem is mainly fuel ignition related not from being at 200 degree's. By the way a factory Mopar radiator I have found to be the best ones of the bunch even out cooling the aftermarket aluminum rads. Search for a A/c max cooling rad for a big block Good Luck
Re: I give up, 440's just run HOT [Re: 69chargeryeehaa] #66109
05/30/08 12:33 PM
05/30/08 12:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what size spacer are you using ? how close is the fan itself to the rad ? how much of the fan is inside the shroud ?
what water pump are you using ?
what guage are you getting your readings from ?
Re: I give up, 440's just run HOT [Re: 69chargeryeehaa] #66110
05/30/08 12:34 PM
05/30/08 12:34 PM
pgh pa
captaindodge Offline
pgh pa
my 69 440 rt charger is the same way since 1973 when i bought it. It is all stock. Are you talking idle in gear or in neutral? I just know when it is 90 degrees outside I don't want to be stuck in traffic! Remember the engine is converting heat energy to mechanical energy. I have learned to just accept it, especially after adding another row to the radiator didn't change anything.
Re: I give up, 440's just run HOT [Re: JohnRR] #66111
05/30/08 12:35 PM
05/30/08 12:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what dist is it ?
Re: I give up, 440's just run HOT [Re: JohnRR] #66112
05/30/08 12:39 PM
05/30/08 12:39 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I would drain the system then refill it with regular water and a bottle of water wetter for the summer.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: I give up, 440's just run HOT [Re: 69chargeryeehaa] #66113
05/30/08 12:42 PM
05/30/08 12:42 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
If it over heats at idle the problem is AIR FLOW. Get rid of the pusher like suggested. If you are running a clutch fan, make sure if is the thermal type (spring in front). If you already have this type, then you will probably have to go to a fixed of flex fan like a Flex a lite stainless blade. Most thermal clutches kick in at around 190*. So it could be free wheeling and not pulling enough air until it's too late. Some other things you might try is maybe using less antifreeze and more water. Just some suggestions that worked for me. Good luck
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
