Special Sockets ?????? #658216
04/01/10 03:56 PM
04/01/10 03:56 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Does anyone know where you can buy some deep sockets with the nylon inserts in them to assemble your painted bolts ? i have checked at Sears and looked on ebay. Thanks Ronnie
Re: Special Sockets ?????? [Re: okie] #658217
04/01/10 07:00 PM
04/01/10 07:00 PM
Santa Barbara, CA
HitIt Offline
HitIt  Offline
Santa Barbara, CA
if you can't find them try using a dryer sheet between the bolt and the socket. Even those nylon ones will chip the paint I'm afraid.
You can also use peices of those blue scott shop paper towels.
Re: Special Sockets ?????? [Re: HitIt] #658218
04/01/10 07:26 PM
04/01/10 07:26 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
I got a set from Matco,they did not work that well,you cannot tighten much at all as the socket insert gets chewed up.
Re: Special Sockets ?????? [Re: HitIt] #658219
04/01/10 07:46 PM
04/01/10 07:46 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Thats a good idea. I never thought of useing those.
Re: Special Sockets ?????? [Re: Dougsmopars] #658220
04/01/10 08:01 PM
04/01/10 08:01 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Paint after final assembly?
Re: Special Sockets ?????? [Re: okie] #658221
04/01/10 10:43 PM
04/01/10 10:43 PM
Phoenix, AZ
3
38371cuda Offline
38371cuda  Offline
Phoenix, AZ
Paint after final assembly. I am a body guy and there is no way to completely keep bolts from chipping. As many times as you have to go back and forth to achieve alignment, touch up is inevitable. If you used 2 stage paint, buy a small amount of single stage for the touch up. Airbrush to be perfect, model brush or Q-tip to be satisfactory.
Re: Special Sockets ?????? [Re: 38371cuda] #658222
04/02/10 08:24 AM
04/02/10 08:24 AM
Australia
charger RTSE Offline
Australia
Only use the six sided sockets and put some electrical tape over the nut or bolt and then do it up.
Re: Special Sockets ?????? [Re: charger RTSE] #658223
04/02/10 10:21 AM
04/02/10 10:21 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
A related thought:
Reportedly pieces of milk jug can be cut into good protective washers to use during body panel alignment -- then remove it for final bolt installation.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
