Re: Special Sockets ??????
[Re: HitIt]
#658219
04/01/10 07:46 PM
04/01/10 07:46 PM
Posts: 2,295 dark side of the moon
Dougsmopars
if you can't find them try using a dryer sheet between the bolt and the socket. Even those nylon ones will chip the paint I'm afraid.
You can also use peices of those blue scott shop paper towels.
Thats a good idea. I never thought of useing those.
[Re: charger RTSE]
#658223
04/02/10 10:21 AM
04/02/10 10:21 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
A related thought:
Reportedly pieces of milk jug can be cut into good protective washers to use during body panel alignment -- then remove it for final bolt installation.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
