Six pack center carb mods #658165
04/01/10 03:04 PM
04/01/10 03:04 PM
Id
mopeman Offline OP
mopeman  Offline OP
Id
Has anyone cut the choke horn off the center six pack carb. I have already removed the choke and want to cut the horn off and polish the throats a little. I have done this on a DP and it worked good.
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: Six pack center carb mods [Re: mopeman] #658166
04/01/10 03:22 PM
04/01/10 03:22 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Depending what the original application was I would hesitate to ruin a carb someone could use.You could probably find someone that would swap you something that is not as desireable in return.
Re: Six pack center carb mods [Re: 62maxwgn] #658167
04/01/10 07:00 PM
04/01/10 07:00 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I had mine milled off to get the 50 CFM or so it adds to the airflow when measured at 1.5"hg. Probably rated as a tad more CFM when measured at the 2 barrel rating of 3"hg. I believe that is the vacumm they use to rate for 2 versus 4 barrel dry air flow.
Re: Six pack center carb mods [Re: 62maxwgn] #658168
04/02/10 04:07 PM
04/02/10 04:07 PM
Id
mopeman Offline OP
mopeman  Offline OP
Id
The carbs are new ones from Summit, so no fear of messing up originals which I wouldn't do if I could get some. I just want to get more performance out of the carbs...I don't use the choke any way, so why not get rid of it.
Mopar or no car
'93 W250 Ram
'68 Charger
