Re: Six pack center carb mods
[Re: 62maxwgn]
#658167
04/01/10 07:00 PM
04/01/10 07:00 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I had mine milled off to get the 50 CFM or so it adds to the airflow when measured at 1.5"hg. Probably rated as a tad more CFM when measured at the 2 barrel rating of 3"hg. I believe that is the vacumm they use to rate for 2 versus 4 barrel dry air flow.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
