Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: dc426] #658040
04/02/10 12:11 PM
04/02/10 12:11 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Well - it may be opinion or it could be fact - but PPP IMO is the best shifter you can buy. Apparently about 95% of the money is no object racers agree. Add in that PPP has never, not once, had a shifter returned due to a defect or malfunction and that is pretty good testimant to the quality and performance.
Whether you are pushing or pulling - it is impossible to inadvertantly mis-shift. Now - push-pull - it is all personal preference.
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: kielbasa] #658041
04/02/10 12:16 PM
04/02/10 12:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Pulling makes more sense especially when g forces are salammin you back in the seat anyhow. I run the hurst pro-matic 2 if it matters.
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: Thumperdart] #658042
04/02/10 03:59 PM
04/02/10 03:59 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
well, my question still is, if I pull to upshift, do I need to pull the lever also? Or just the handle - because if I have to pull both to upshift, then obviously I'd rather push (or "slam") just the handle to upshift.....
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: kielbasa] #658043
04/02/10 04:07 PM
04/02/10 04:07 PM
WI.
4Huntin Offline
4Huntin  Offline
WI.
On the Hurst 1/4 stick you need the lever for
third, and to get reverse and park.
Steve
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: 4Huntin] #658044
04/02/10 05:15 PM
04/02/10 05:15 PM
Mt.Vernon ,Ohio
VernMotor Offline
Happy Birthday VernMotor  Offline
Mt.Vernon ,Ohio
PPP you do not have to pull the level to shift.. just to put it in reves..
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: VernMotor] #658045
04/02/10 05:57 PM
04/02/10 05:57 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I Haven't tried them all, But for my I will be using a pro-ratchet till im in the ground.
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: 727builder] #658046
04/02/10 06:29 PM
04/02/10 06:29 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
B&M Stealth Pro Rachet. Currently running a forward manual vb, soon to switch to a reverse. The shifter doesn't care!
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: 727builder] #658047
04/02/10 06:45 PM
04/02/10 06:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One thing that I like about the pro ratchet is that
it returns to the same spot after you shift... it doesnt
keep getting farther or closer with each shift
383man [Re: MR_P_BODY] #658048
04/03/10 12:15 AM
04/03/10 12:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like the reverse manual v/b as to me it is much easier pulling the shifter to me when racing. Ron
Re: 383man [Re: 383man] #658049
04/03/10 05:55 AM
04/03/10 05:55 AM
Cambridge Vt.
mark_gates Offline
mark_gates  Offline
Cambridge Vt.
For years I had a TF2 forward action vb with a B&M Z gate forward action and got along well with it, then I got a CRT FMVB and installed the B&M ProRatchet. Works even better!
Re: 383man [Re: mark_gates] #658050
04/03/10 08:10 AM
04/03/10 08:10 AM
Mt.Vernon ,Ohio
VernMotor Offline
Mt.Vernon ,Ohio
Dam Mark is that realy you ! I thought you fell off the earth or something...Good to see you post
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: 727builder] #658051
04/03/10 08:11 AM
04/03/10 08:11 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
Me also Just as Mr P pointed out it returns to the same position everytime
