Should yellow park lights turn off when headlights on #657928
04/01/10 10:07 AM
04/01/10 10:07 AM
Town of North East, Pa.
K
k3522 Offline OP
k3522  Offline OP
K
Testing lights on my 68 Satellite and when the light switch is on park mode all running light except headlights are on. When I swich to headlight mode the front bumper yellow lights turn off and obviously the headlight turn on. Does that seem correct on a 68 Satellite or is there something wrong with my switch? One more thing, with the headlights on and the front yellow lights off they still work for turning signaling.
Re: Should yellow park lights turn off when headlights on [Re: k3522] #657929
04/01/10 10:09 AM
04/01/10 10:09 AM
scratchnfotraction Offline
thats is the correct way it should work for a 68
DOT law changed in 69 so the park/turn lights are on when headlights are on IIRC
Re: Should yellow park lights turn off when headlights on [Re: scratchnfotraction] #657930
04/01/10 10:12 AM
04/01/10 10:12 AM
and your other Q, there's 2 filaments in each bulb, a small one for the above park lights and a brighter one for the turn signals
Re: Should yellow park lights turn off when headlights on [Re: RapidRobert] #657931
04/01/10 10:26 AM
04/01/10 10:26 AM
K
k3522 Offline OP
k3522  Offline OP
K
Thanks.
Re: Should yellow park lights turn off when headlights on [Re: k3522] #657932
04/01/10 11:31 AM
04/01/10 11:31 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
BTW, switches are the same... the diff is just a jumper wire on harness/plug to keep still working the front parking lights when headlights are on. Switch will be still cuting the power to those, jumper wire jumps that cut
