Freshened up 440 Knock? #656551
03/30/10 10:53 PM
03/30/10 10:53 PM
CO
I
ihv800 Offline OP
ihv800  Offline OP
I
CO
Hey guys, just got done freshening up a 440 that flattened a cam. Put new head gaskets on it, new cam, lifters, and cam bearings. While it was apart I put main and rod bearings in. Got it fired up for the first time last night to break the new cam in. Started great, and ran good for around 3 minutes. It developed a tick which in a fairly short period of time progressed to a full on knock. My feelings tell me it's a rod. I will be pulling the pan off tomorrow. Wondering if you guys any thoughts on what could be wrong and why? Little frustrated at the moment and my mind isn't thinking like it should.
Re: Freshened up 440 Knock? [Re: ihv800] #656552
03/30/10 11:25 PM
03/30/10 11:25 PM
Sorry for the bad outcome. Visually eyeball the rod big ends for anything not kosher, "shake each rod" to check for side clearance. Check the torque that each of the rod bolts is tightened to
Re: Freshened up 440 Knock? [Re: ihv800] #656553
03/30/10 11:25 PM
03/30/10 11:25 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
After you wiped the first cam, did you pull the motor apart to clean all the metal shavings out? Something easily could have gotten back into the oiling system.
Re: Freshened up 440 Knock? [Re: DaytonaTurbo] #656554
03/30/10 11:31 PM
03/30/10 11:31 PM
CO
I
ihv800 Offline OP
ihv800  Offline OP
I
CO
I'll be sure to check all that out!
The cam it wiped was the original one. This was the first time the motors ever been apart, and I cleaned it out thoroughly, its defiantly a thought though!
Thanks for the help and thoughts guys!
Re: Freshened up 440 Knock? [Re: ihv800] #656555
03/31/10 02:56 AM
03/31/10 02:56 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
One year ago I wiped a cam in a fresh rebuild. I swapped it out and even replaced the oil pump, as the inner and outer rotors had metal embedded in them. I was sure that I would be okay. 200 miles later I spun 2 rod bearings. I figure that the bearings were already going bad at the time I replaced the cam but took a little while to get bad enough to notice. Oddly it only wiped ONE lobe, but that was enough to send a stream of debris through the motor.
Re: Freshened up 440 Knock? [Re: Kern Dog] #656556
03/31/10 04:30 AM
03/31/10 04:30 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Hot tank the block. Run bore brushes through all oil passages. Y ou cant get it too clean.
Re: Freshened up 440 Knock? [Re: bobby66] #656557
03/31/10 12:35 PM
03/31/10 12:35 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Yeah, I'm be wondering if you used brushes and cleaned all the passages. Just hosing what you can see isnt enough. Or the possibility of a rod not being torqued properly?
Re: Freshened up 440 Knock? [Re: moper] #656558
03/31/10 03:06 PM
03/31/10 03:06 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
what were the bearing clearences when you put it together and how were they measured?
Re: Freshened up 440 Knock? [Re: Baxter61] #656559
03/31/10 08:34 PM
03/31/10 08:34 PM
CO
I
ihv800 Offline OP
ihv800  Offline OP
I
CO
Got the pan off and found a cap very loose. I thought I double checked everything, guess next time I'll double-double check it! Everything is fine except for a few nicks in the bearing which I will be replacing! Glad it only ran seconds with the knock!
