Re: Freshened up 440 Knock?
[Re: ihv800]
#656552
03/30/10 11:25 PM
03/30/10 11:25 PM
RapidRobert
Sorry for the bad outcome. Visually eyeball the rod big ends for anything not kosher, "shake each rod" to check for side clearance. Check the torque that each of the rod bolts is tightened to
[Re: bobby66]
#656557
03/31/10 12:35 PM
03/31/10 12:35 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Yeah, I'm be wondering if you used brushes and cleaned all the passages. Just hosing what you can see isnt enough. Or the possibility of a rod not being torqued properly?
