Page 3 of 5 1 2 3 4 5
Re: first thing you learn about drag racin? [Re: Pacnorthcuda] #656280
03/30/10 10:28 PM
03/30/10 10:28 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
"never lift"
I love it when guys don't lift. The best part is you don't even have to give 'em any of your winnings.
Re: first thing you learn about drag racin? [Re: RemCharger] #656281
03/30/10 10:34 PM
03/30/10 10:34 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
I never done it, Dont take off to the lanes dragging you battery charger still hooked up?
Re: first thing you learn about drag racin? [Re: ben1692] #656282
03/30/10 11:09 PM
03/30/10 11:09 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Good way to spend hard earned $$$$$$
Re: first thing you learn about drag racin? [Re: qwkmopardan] #656283
03/30/10 11:20 PM
03/30/10 11:20 PM
Hemiroid Offline
Hemiroid  Offline
"The best way to make a small fortune in drag racing is to start with a big one!!"
Re: first thing you learn about drag racin? [Re: 727builder] #656284
03/30/10 11:29 PM
03/30/10 11:29 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
"That you can make sure that your engine, trans, diff, tires, belts, air pressure, battery, fuel ect, ect, ect have been checked and rechecked and still some little $5 part that never fails, can fail at the most inopertune time and cost you the race."
My first race ever, TT's go ok, 1st rd in stageing lanes, start the car, pull up and shut off 6 or 7 times, no problem. Get to the head of the lane, wait for starters signal, start car, go to put in gear and the reverse lock out button on the slap stick goes in and sticks in. in park... Got timed out, then got yelled at to move my car so the rest of the cars can race In about two minutes I went from to
And 20 years later it's still happening. At Mopar meet at Bristol last year, I make 6 time trials, no problem. 1st round, under the tower, engine already running, 15 seconds from pulling into burn out, my opponants crew runs over and said " you got a flat". Yeah, right. By the time I got out and looked, the rim was almost on the ground. I pick up a nail in the LR slick that went between the tube and inside of sidewall and ripped a big gash in the tube. Could not even get it fixed in time to buy back.
Brian
Re: first thing you learn about drag racin? [Re: '72CudaRacer] #656285
03/30/10 11:32 PM
03/30/10 11:32 PM
PA
moparacer Offline
moparacer  Offline
PA
Dont stage with the back tires......
The first time I was ever at a drag strip one of my friends did that.
The laughter and ridicule he had to endure is still burnt into my memory.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: first thing you learn about drag racin? [Re: moparacer] #656286
03/30/10 11:56 PM
03/30/10 11:56 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
dont wait for the light to turn green. after six first round losses, i asked a racer what i was doing wrong and he said leave on the last yellow. wow what a differance.
Re: first thing you learn about drag racin? [Re: Deepockets] #656287
03/31/10 12:11 AM
03/31/10 12:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Welcome to the jungle.... a first time poster
Re: first thing you learn about drag racin? [Re: 70Cuda383] #656288
03/31/10 12:19 AM
03/31/10 12:19 AM
iowa
rook440 Offline
rook440  Offline
iowa
never but never say what your car will run till it actually runs it ....
Re: first thing you learn about drag racin? [Re: rook440] #656289
03/31/10 12:43 AM
03/31/10 12:43 AM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Never ever brag how fast or how good of a driver you are. I had a friend who would mouth off in front of everyone at drivers meetings. Most of the guys,even the mild mannered ones would do anything they could to beat him and usually did.
Re: first thing you learn about drag racin? [Re: b1dartsport] #656290
03/31/10 12:54 AM
03/31/10 12:54 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Well lets see..it was 1963 or 64 and the RAMCHARGERS were kicking butt...and MOPARS rule!
Post deleted by Defbob [Re: 52savoy] #656291
03/31/10 01:03 AM
03/31/10 01:03 AM
Re: first thing you learn about drag racin? [Re: DoubleD] #656292
03/31/10 02:47 AM
03/31/10 02:47 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
If you cant put a couple hundred dollars in your hand and light on fire - then laugh while it burns -You ain't ready to go drag racing!
this is so true... or in my recent case $1500 worth of trans, tailshaft & starter motor, could have been ALOT worse but Im laughing because it happened to my GM
Re: first thing you learn about drag racin? [Re: ben1692] #656293
03/31/10 06:47 AM
03/31/10 06:47 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
If it feels funny, get out of it.
The accelerator pedal that is.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: first thing you learn about drag racin? [Re: bigsbigelow] #656294
03/31/10 07:25 AM
03/31/10 07:25 AM
ny
greenmcode Offline
greenmcode  Offline
ny
HURRY up and WAIT!!!.. Thats one thing
i learned..
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
Re: first thing you learn about drag racin? [Re: greenmcode] #656295
03/31/10 08:28 AM
03/31/10 08:28 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
You meet a whole lot of great people out there and some of them become your best friends
Russ
Re: first thing you learn about drag racin? [Re: MR_P_BODY] #656296
03/31/10 08:48 AM
03/31/10 08:48 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
If you race multiple cases of racing as in pro and
super pro........... remember not to leave on the
top bulb when in pro........ DOH
Funny, I was drafted into a class by a great group,they told me where we pitted,where the drinks were,where the hot dogs were,told me everything I could ever have needed to know, except that they run a pro tree, I stage look down to check guages,look up hey how long has that green light been on and where's the duster going. Not very often that you can shave 1.5 seconds off your reaction time. They still laugh about it.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: first thing you learn about drag racin? [Re: FurryStump] #656297
03/31/10 08:58 AM
03/31/10 08:58 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Be safe, know the layout of the track. dont drive 50 in the pits, lots of people walking around there. If you run a dragster, dont coast threw the pits, people cant hear you coming. And remember kids dont know better...Have fun...Phill
Re: first thing you learn about drag racin? [Re: ben1692] #656298
03/31/10 09:34 AM
03/31/10 09:34 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
don't wait for the green light to "Go"
Coming soon!!!!
Re: first thing you learn about drag racin? [Re: A70Runner] #656299
03/31/10 09:46 AM
03/31/10 09:46 AM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
Don't stage with the back tires?
I had this happen once years ago. Hit the brake button, didn't hold. Stopped the car with brakes exactly fulled staged w/slicks. Confused starter guy (and us). He run the tree anyway I launched, but let off knowing it was foul.
