Question on installing wide band O2 sensor #655654
03/30/10 09:18 AM
03/30/10 09:18 AM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
I need to decide on which header to mount the O2 bung. I know that some cylinders can run richer/leaner than others but is the same true for an entire side of an engine? The sensor is going on a 440. Thanks.
Re: Question on installing wide band O2 sensor [Re: whitemtnelf] #655655
03/30/10 10:04 AM
03/30/10 10:04 AM
Weld in bungs on each header so you can get each bank dead on so nothing is being left on the table and you are getting the maximum info out of your investment
Re: Question on installing wide band O2 sensor [Re: RapidRobert] #655656
03/30/10 01:23 PM
03/30/10 01:23 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
Also ensure the sensor is above the 9 and 3 oclock position. You do not want the sensor below as moisture will collect in the sensor and wreck it.
Re: Question on installing wide band O2 sensor [Re: six-barrel] #655657
03/30/10 01:32 PM
03/30/10 01:32 PM
New Hampshire
W
W
New Hampshire
the gauge kits on Summit are for a single sensor. Are you suggesting putting two sensors in and switching the connection to the gauge to read both sides? I don't want/need to spend many hundreds of dollars on this, I just want something to help me tune the carb.
Re: Question on installing wide band O2 sensor [Re: whitemtnelf] #655658
03/30/10 01:40 PM
03/30/10 01:40 PM
Andrewh Offline
Andrewh  Offline
no reason to do that.
The kit I bought came with a plug.
just buy an extra bung and plug the one you are not using. or I guess the kit was so I could take it out after tuning and plug it for all time.
Re: Question on installing wide band O2 sensor [Re: Andrewh] #655659
03/30/10 03:41 PM
03/30/10 03:41 PM
Correct, an extra bung cannot be too much $$ and you'll know what you have on each half.
Re: Question on installing wide band O2 sensor [Re: RapidRobert] #655660
03/30/10 04:24 PM
03/30/10 04:24 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Just put one sensor in one header collector and be done with it. Unless something goes seriously wrong with your carb or ignition system, a/f will be the same in both banks.
