Worm gear replacement #653897
03/28/10 06:12 PM
03/28/10 06:12 PM
70duster340 Offline OP
How difficult is the job of replacing a worm gear in a manual steering box? Mine is the standard 26:1 ratio, and I see that Mancini offers a 20:1 worm gear. Is this a difficult task, and would it be noticable?
TIA!!!
Re: Worm gear replacement [Re: 70duster340] #653898
03/28/10 06:20 PM
03/28/10 06:20 PM
Kirkland, Washington
Pacnorthcuda Offline
I had it done (so I can't tell you about difficulty) on a 70 barracuda. Manual Steering.
It was VERY noticeable--huge improvement. Heavy in parking lots though.
But why not just get a fast ratio pitman?
Re: Worm gear replacement [Re: 70duster340] #653899
03/28/10 06:21 PM
03/28/10 06:21 PM
Port Hope, Ontario
TheMoparJunky Offline
mopar addict
mopar addict
Port Hope, Ontario
Mopar Muscle did a full rebuild a while back(with help) and looks to be very simple if you are familiar with taking apart gear boxes, 4 speeds, whatnot.
I thought they had to press a shaft or bearing back in(manual or electric hydraulic).
http://www.moparmusclemagazine.com/techa..._box/index.html
This is an article of a saginaw steering box:
http://www.moparmusclemagazine.com/howto/mopp_0103_how_to_install_saginaw_steering_box/index.html
Have fun.
The Mopar Junky
Back off the Mopar bandwagon- Wannabe Millwright Enjoying the fat lazy unemployed life
Re: Worm gear replacement [Re: TheMoparJunky] #653900
03/28/10 06:29 PM
03/28/10 06:29 PM
Well, would a fast ratio pitman arm be an easier solution? If so, where can I get one?
Re: Worm gear replacement [Re: 70duster340] #653901
03/28/10 06:35 PM
03/28/10 06:35 PM
Check with www.firmfeel.com
Re: Worm gear replacement [Re: Pacnorthcuda] #653902
03/28/10 06:49 PM
03/28/10 06:49 PM
Thanks, Pacnorthcuda. I checked the Firm Feel website, and it states that I need the 73-76 drag link. My car was orginally a /6 car, way before I bought it. How can I know if I have this drag link? Anybody have a pic so I can compare?
Re: Worm gear replacement [Re: 70duster340] #653903
03/28/10 06:59 PM
03/28/10 06:59 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
firm-feel advertises a rebuild kit for manual boxes on their site,with all seals and bearings needed it says.im going 20:1 and am waiting for email response from them.do it
Re: Worm gear replacement [Re: cuda-sweden] #653904
03/28/10 11:03 PM
03/28/10 11:03 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Not hard to do at all. Only real thing to note is that you need an inch pound torque wrench to do the adjustment. I think it takes a 12 point socet to fit on the column spline end to check that adjustment I'm talking about.
Two bolts that fit into the holes, that makes you an adjuster.
The race at the bottom of the box is the real wild card. The one I did was in good shape. I don't know what you would do if that race needed to be changed...
I want my fair share
