Steering shaft length question #65375
05/28/08 09:11 PM
05/28/08 09:11 PM
Rancho Cucamonga, Calif.
P
PUNK Offline OP
PUNK  Offline OP
P
Does anyone happen to know the differance in length between a manual steering shaft and a power steering shaft? Im converting over to power steering on a Challenger and want to know the differance. I was told to just collapse the steering shaft to shorten it up. But by how much??
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Steering shaft length question [Re: PUNK] #65376
05/28/08 09:27 PM
05/28/08 09:27 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I sure wouldn't do that. That will take the strength out of the column. Rather cut it and have a good machine shop make a splice. Can be done safely and non noticeable.
Re: Steering shaft length question [Re: PUNK] #65377
05/28/08 09:30 PM
05/28/08 09:30 PM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
The manual column is something like 2" longer. Trying to shorten the power column by collapsing it won't work because you need a shorter section out in front of the firewall, which doesn't change when the shaft collapses. Best to find a power column in the boneyard.
Re: Steering shaft length question [Re: PUNK] #65378
05/30/08 12:01 AM
05/30/08 12:01 AM
In
P
ply426 Offline
ply426  Offline
P
In
I've done it a couple of times... worked fine....
One of the greatest cover-ups of the last century was the fact that Hitler did not commit suicide in his bunker, but was in fact tea-bagged to death by Chuck Norris.
Re: Steering shaft length question [Re: ply426] #65379
05/30/08 09:37 AM
05/30/08 09:37 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
A manual shaft will collapse just fine. I have done it a number of times. It's not a good idea to try and stretch a P/S shaft to fit a manual set up.
Re: Steering shaft length question [Re: stumpy] #65380
09/21/10 11:41 PM
09/21/10 11:41 PM
SC
BPDodge Offline
BPDodge  Offline
SC
according to a genuine old mopar parts catalog I have,the power steering shaft is 3.1 inches shorter than the manual shaft. The 2 measurments are listed to 3 decimal points.
I am going to cut the shaft that measurment and drill the roll pin hole with a hardened bit. It looks like it will fit perfectly.
Re: Steering shaft length question [Re: PUNK] #65381
09/22/10 12:49 AM
09/22/10 12:49 AM
one adv of early A's, the 1 piece inner steering shafts directly interchange in the column. going w PS on my 65 dart & just need the shorter inner shaft & the different coupler
